Thread: Air intake flap motor V157 no signal
  1. Air intake flap motor V157 no signal
    Oct 2006
    Collier Street
    Hi all
    Got the dreaded v157 no signal a while back, so bought a 2ndhand unit but still had the same code, am about to bite the bullet & get a new 1 (£189), but have a nagging doubt about wiring issue.
    When I unplug it, the code changes to open circuit. so I'm assuming there are no breaks in the wiring as a broken cable would throw up an open circuit code all the time. Am i correct in this assumption? As I don't really want to spend £189 on a new unit if it's a wiring issue.
    My knowledge of auto electrics is non existent, but I do have a multi-meter & armed with the knowledge of how to check it, I think I could probably manage it.
    I have read that the air intake motor sensor gets crapped up & fails, so should I just grab a new 1 & ft it.
    Robin
    Robin
    VW Caddy 2.0 SDi 2008 BST Eng JJS Box
  2. Re: Air intake flap motor V157 no signal
    1840 Post(s)
    Without being at work and using ELSA to check I cannot see if that one is fused.
  3. Re: Air intake flap motor V157 no signal
    Oct 2006
    Collier Street
    Both of the units (original 1 & the 2nd hand 1) I've got work, just no signal. I've had the hose off & watched them open & close. Hence my concern about wiring, but if it's probably the sensor inside the unit not sending a signal then I'll have to grab a new 1.
    I suppose my question is, what has been other people's experience, is it normally the unit screwed web this fault code?
    Robin
  4. Re: Air intake flap motor V157 no signal
    1840 Post(s)
    If it is operating then it is most likely the unit at fault, this is why I won’t use second hand parts as I can’t afford the lost time.
  5. Re: Air intake flap motor V157 no signal
    Oct 2006
    Collier Street
    Ok, so I've put a new 1 on & still getting the same fault code 157 no signal. Does the new unit need to be coded for my van? I've heard they are plug & play, but they go in a variety of different cars & vans, so surely they'd need some sort of coding. Any suggestions/help greatly appreciated. Also have another issue, but will post in another thread as I don't think it's related.
    Robin
  6. Re: Air intake flap motor V157 no signal
    1840 Post(s)
    Remind me tomorrow and I will check the wiring diagram
  1. Motor for Intake Manifold Flap (V157): Malfunction
    By b1nuzz in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-11-2019, 02:46 PM
  2. Motor for Intake Manifold Flap V157 Malfunction P3103
    By Bubbauk in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-02-2017, 11:11 PM
  3. Please Help V157 P3101, P3102 Motor for intake manifold flap MIL Fault investigation
    By rabb5it in forum Golf MK5 - 2004 - 2009
    Last Post: 21-04-2014, 10:53 AM
  4. P3103 V157 - Motor Intake Manifold Flap
    By James Clews in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-02-2014, 09:33 PM
  5. Intake Manifold Flap (V157)
    By SebastianTDI140 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-06-2010, 08:07 PM
