Thread: [A3 8P 1.4TFSI CAXC, 125HP, DSG] startup problem on warm days.
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: [A3 8P 1.4TFSI CAXC, 125HP, DSG] startup problem on warm days.
    Jun 2019
    Katowiz
    Around ~1 min, and only when is warm outside.
    For example - today morning we had 5*C and car start without problems. Few seconds and revs drop to 750.
  2. Re: [A3 8P 1.4TFSI CAXC, 125HP, DSG] startup problem on warm days.
    1841 Post(s)
    It does sound like the warm up phase, a chain issues would only last a second or two.
  3. Re: [A3 8P 1.4TFSI CAXC, 125HP, DSG] startup problem on warm days.
    Jun 2019
    Katowiz
    But should car shakes so hard during warm up phase? And shouldn't it rather happen on winter? Not in summer when we have 20*C and more?
  4. Re: [A3 8P 1.4TFSI CAXC, 125HP, DSG] startup problem on warm days.
    1841 Post(s)
    It can make them run rough but I can’t experience it myself. The cat needs to exceed 420 degrees Centigrade to start converting emissions to Co2 so the ambient temperature has very little bearing on this.
  5. Re: [A3 8P 1.4TFSI CAXC, 125HP, DSG] startup problem on warm days.
    Jun 2019
    Katowiz
    Hmm I will ask my friend to borrow me his lap and vcds cable, and I will try to collect some logs on mornings when the car have these problems. I guess I will have to run it few times, every few hours (or just every morning before I will go to work)
    Do you know which blocks if worth to check and make logs? I don't think I can collect all at once, and definitely all are not required.
  6. Re: [A3 8P 1.4TFSI CAXC, 125HP, DSG] startup problem on warm days.
    1841 Post(s)
    VCDS has a list of the measuring blocks, run through the list and you can select up to 12 at once.
  7. Re: [A3 8P 1.4TFSI CAXC, 125HP, DSG] startup problem on warm days.
    #17
    Jun 2019
    Katowiz
    My laptop has died (ffs...), so no chance for my to make all the logs using VCDS, buuut I managed to borrow OBII Bluetooth adapter and I made logs using Torque app.
    any chance you can take a look on it and check if you see something strange... I tried to look into it but emm I'm totally newbie
    Thanks!
    Two logs, one from morning and one from afternoon.
  8. Re: [A3 8P 1.4TFSI CAXC, 125HP, DSG] startup problem on warm days.
    #18
    1841 Post(s)
    I can't tell anything from that, I would have to turn it all into an Excel graph and I have a Golf 5 GTI to get running.
  9. Re: [A3 8P 1.4TFSI CAXC, 125HP, DSG] startup problem on warm days.
    #19
    Oct 2020
    Oslo, Norway
    Hello,
    I have exactly the same car and the same problem. Mostly when is worm outside. No errors on tester so probably mechanical. Did you manage to fix it?
  1. Question Car jerks on warm days
    By LiamP1985 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-05-2019, 08:40 PM
  2. 3.0TDi Lockup on startup when warm, no smoke at all though
    By zit501 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-02-2019, 07:01 AM
  3. Please Help Hydrolock on a warm startup?
    By Mrhawx in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-01-2018, 05:53 PM
  4. Replies: 3
    Last Post: 15-09-2015, 03:29 PM
  5. Stuttering at 1800rpm only on warm days ??
    By JIMMER15 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-05-2013, 08:35 AM
