Thread: Anti Shudder valve fuse
  1. Anti Shudder valve fuse
    Jun 2019
    HI
    2007 A4 140BHP TDI Cabriolet
    Hoping some one can point me in the right direction
    codes of V157 Intake manifold flap open or short to ground P3101
    Solenoid valve N75 short to ground P0245
    changed the anti shudder valve .....full of oil
    still wont clear down the codes
    is the a fuse that controls these ?.......checked at the side of the dash and under the dash..all seem OK
    and hidden ones?.......or thoughts why the codes will not clear down
    many thanks
    Nick
  2. Re: Anti Shudder valve fuse
    1836 Post(s)
    Some are fused some are direct from the ECU but I can’t remember which one on the A4 as I am off work. I will look it up on Monday if no one else has been able to help you before.
  3. Re: Anti Shudder valve fuse
    Jun 2019
    That would be great thanks
    Nick
  4. Re: Anti Shudder valve fuse
    1836 Post(s)
    I am assuming it is a BPW engine but the alternative BRC is the same. The V157 shares its fuse with the turbo N75 valve, N144 left engine mount, F36 clutch pedal switch, J179 glow plug controller and the fuse is a 15amp located in the plenum chamber water box at position A but if it was blown I would expect more codes and appropriate problems.
  5. Re: Anti Shudder valve fuse
    Jun 2019
    HI
    Thank you for the information
    and yes i do have all of those codes apart from clutch one......(automatic)
    will let you know how i get on ...looks fun to get the lid off !
    once again thank you
    Nick
  6. Re: Anti Shudder valve fuse
    Jun 2019
    Absolutely sort on with your advise
    hidden under the ECU
    changed the fuse all codes cleared down
    thanks again
    Nick
    1 1 0
  1. Anti shudder valve connection
    By MrPassat02 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-11-2017, 08:15 PM
  2. Oil from Anti-Shudder valve?
    By Mario in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-05-2017, 11:43 PM
  3. 1.9 TDI anti shudder valve clicking /buzzing -ignition off
    By Rob69 in forum Touran - Sharan - Caravelle
    Last Post: 30-01-2015, 07:31 PM
  4. Anti Shudder Valve shutting down engine
    By Davob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-09-2010, 10:00 PM
  5. Have you replaced your TDi EGR? Anti Shudder Valve needed
    By craig.scoobsvil in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-09-2010, 10:15 PM
