Thread: Key Fob Malfunctioning
  1. Key Fob Malfunctioning
    Oct 2009
    yorks england
    Sorry if this post is in the wrong section but couldn't find any non-model specific sections. I have the fairly standard 3 button black key fob that flicks open. One of the 2 fobs seems to be malfunctioning and sending a constant "close door" signal. When its battery is in I can't even use the other (good) fob to open the door as it seems to be overruled by the faulty one. I've tried a new battery, reprogramming it (hold "open" button, insert key, turn to second position still holding key, turn back to off, remove, release) with no joy. I've opened it up and the buttons aren't physically jammed ie I can press/depress each button ok. Wondering if anyone has experienced this and/or has any other suggestions for me to try?
    Many thanks
    NB
  2. Re: Key Fob Malfunctioning
    Jul 2008
    Lisburn
    15 Post(s)
    was it messy / sticky inside? could be causing a short can you measure resistance with no batteries fitted across the switch? - tv remotes get all gummed up i strip and clean in luke warm water and fairy liquid. for the key with physical buttons i would leave it to dry for a couple of days before inserting batteries again.
    tin whiskers are real as well but normally fuse straight away then grow again.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
