Thread: P0036 code 1.0 polo
  1. P0036 code 1.0 polo
    Jun 2019
    Midlands
    Had this code pop up on daughters car, reset the fault but it came on again when she next used it.I understand its a fault with the sensor after the cat convertor.
    Are there any tests i can do on this sensor or is it usually just the case of replacing it?
    if i need replacement wheres best place to get it, not sure how to get the part number, reg is fy64 ukx.
    any info appreciated 👍
  2. Re: P0036 code 1.0 polo
    1840 Post(s)
    16420 (P0036)- Oxygen sensor B1 S2: Heating Circuit: Malfunction / Open Circuit
    Yes this is the post cat sensor. It could be a wiring fault or even a blown fuse so testing the sensor had battery voltage with the engine running would be advisable. I get the part number as 04C 906 262 K and from a VW dealer these are £149.12 but you should be able to get a Bosch 0 258 030 133 for much less
  3. Re: P0036 code 1.0 polo
    Jun 2019
    Midlands
    Thanks for the info,it does have power going to it so will try a replacement.
    Thats the price VW quoted me today but would not tell me what the part number was,said they no longer give that info out but after some research i came to the same part numbers provided by you.
    Incase anybody else looking for one.
    VW POLO 1.0 Lambda Sensor Post Cat 2014 on Oxygen Bosch VOLKSWAGEN Quality New 4047025640558 | eBay
    @ £63.65
    Before purchashing i have asked for confirmation its a genuine bosch one as advertised.
  1. How To Gearbox code 97 Polo
    By scubbay in forum Polo - Derby - Lupo - Fox
    Last Post: 02-02-2017, 01:15 PM
  2. polo 1.2 AWY O2 sensor 2 P0036 code
    By shep73 in forum Polo - Derby - Lupo - Fox
    Last Post: 06-01-2017, 10:09 PM
  3. polo 1.2 engine code
    By mudstuck in forum New Member Introductions
    Last Post: 18-01-2012, 03:46 PM
  4. Please Help Polo Fault code p0172
    By martin77 in forum Polo - Derby - Lupo - Fox
    Last Post: 15-07-2011, 11:13 AM
  5. Please Help POLO 1.6 GLX GEARBOX CODE N.reg
    By polo1.6slammed in forum Polo - Derby - Lupo - Fox
    Last Post: 01-11-2008, 08:48 PM
