Thread: EPC Light
  1. EPC Light
    Nov 2016
    i have a 2014 leon fr petrol with 84k on the clock, when i start my car the epc light is on, if i turn it off then straight back on it goes out, then after driving it it sometimes comes back on, and the stop start stops working, but there is no lack of power or sluggish performance, what could this be , anyone know ? surely it cant be anything to drastic as it does not affect the performance, im looking to sell the car but really need to fix the issue first,
  2. Re: EPC Light
    1836 Post(s)
    You need a fault code read to see what is wrong, there are so many possibilities guessing would be very risky, a well known culprit is the brake pedal position sensor is becoming an issue on the MQB platform but the repair kit is only £28.
  3. Re: EPC Light
    Nov 2016
    p2563 Turbo boost position sensor, but the turbo boosts ok, ive read up and alot of people are saying brake light switch is the main cause of the epc light coming on, surely not in this case?
  4. Re: EPC Light
    1836 Post(s)
    18995 (P2563) - Turbocharger Boost Control Position Sensor Circuit: Implausible Signal
    This will require the turbo to be removed and rebuilt
    The MQB platform does not use a brake pedal switch as such like the previous PQ35 which had a dual circuit brake pedal switch and brake light switch function.
  5. Re: EPC Light
    Nov 2016
    if the turbo needs a rebuild why does it still boost ok, no performance issues at all ?
  1. Question DPF Light, Flashing Glow Plug Light & Engine Management Light on
    By Jockeyblade in forum Golf MK5 - 2004 - 2009
    Last Post: 19-02-2020, 07:34 PM
  2. R/h reverse light and rear fog light light playing up
    By Panzerdriver in forum Passat CC
    Last Post: 01-12-2017, 10:32 PM
  3. should i buy? abs light, esp light and handbrake light flashing
    By craigq in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-09-2011, 03:36 PM
  4. audi 53 plate esp light on abs light on handbrake light flashing
    By craigq in forum Chat - Anything with wheels
    Last Post: 03-09-2011, 08:58 PM
  5. Brake light changed diesel coil light and brake light still on
    By Manny.p in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-09-2010, 02:04 PM
