Thread: B7 A4 Avant Quattro S line- Where to put axle stands?
  1. B7 A4 Avant Quattro S line- Where to put axle stands?
    Oct 2011
    Solihull
    I need to raise the rear end and remove the rear wheels but it isn't obvious where to place axles stands because of the plastic s-line sill mouldings. Not a lot of metal visible. Any suggestions please?
    Same question applies to the front end while I'm at it, thanks in advance.
  2. Re: B7 A4 Avant Quattro S line- Where to put axle stands?
    Oct 2014
    London, UK
    9 Post(s)
    If you don’t mind deforming the plastic a little, there is the same metal ridge all the way under the plastic.
    I usually use the edge of the plastic/visible metal for the jack and then place the axle stand on the visible metal
  3. Re: B7 A4 Avant Quattro S line- Where to put axle stands?
    Oct 2011
    Solihull
    Thanks OliNix, that's great
  4. Re: B7 A4 Avant Quattro S line- Where to put axle stands?
    1840 Post(s)
    Most modern VAG cars are very difficult to jack up and put on axle stands safely, we see huge numbers of cars with sills wrecked by trolley jacks. The 2008 onwards jacking pad locations have made it easier IF the person with the trolley jack has the pads Audi A4 (2008-2016) Powerflex Jack Pad Adaptor PF3-1660 | eBay
  5. Re: B7 A4 Avant Quattro S line- Where to put axle stands?
    Oct 2011
    Solihull
    Thanks, but given mine is a 2006 and doesn't have the capacity to accept the powerflex jack pad do you have any suggestions on how to safely support it while I remove the rear wheels?
  6. Re: B7 A4 Avant Quattro S line- Where to put axle stands?
    1840 Post(s)
    To be honest and it may sound odd but it is a job I have very little experience of as I have only ever lifted an 8E on a two post lift, my reply was more of a general observation of the problem. From memory of the underside it is a car I would not like to lift on a trolley jack for fear of causing sill damage so I would use a thick block of wood (we use these to get at the lift points of awkward vehicles like the T5) under the sill but where to put the axle stand, I could not recommend.
  7. Re: B7 A4 Avant Quattro S line- Where to put axle stands?
    Oct 2011
    Solihull
    Thanks, understood
  1. B8 Audi A4 Avant S Line Quattro 170 Rear Axle/Wishbone Level Sensor Linkage Broken
    By uncleron in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-01-2013, 05:26 PM
  2. Axle Stands...
    By Stuart_B in forum Chat - Anything with wheels
    Last Post: 23-06-2009, 07:55 PM
  3. Where to put ‘axle-stands’?
    By Space Cadet in forum Archive posts
    Last Post: 13-07-2007, 08:49 AM
  4. Where to put axle-stands?
    By Space Cadet in forum Audi A3 - Archive Topics
    Last Post: 11-07-2007, 09:06 AM
  5. Using axle stands
    By vincentbob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-05-2007, 09:35 PM
