Thread: dreaded chain failure on tsi engine
  1. dreaded chain failure on tsi engine
    Jun 2019
    gosport
    Morning,
    I need some help with finding a very good engine supplier, been looking on the net and don't seem to be able to find a reliable supplier, reviews are terrible or are being investigated by trading standards etc.
    My local garage has quoted 4k for a rebuild (vw specialists) so I'm thinking of a recon engine which will be a little cheaper. I live on the south coast near Portsmouth so any recommendations would be appreciated.
  2. Re: dreaded chain failure on tsi engine
    1837 Post(s)
    Which car, year and engine code? Personally I will not fit a reconditioned engine from anyone except VAG but a friend of mine has just fitted one in a 2009 Golf 6 GTI (EA888) we had in where the owner could not afford a genuine engine so I will ask him if it was any good and who built it. We won’t fit used engines either and initially he was going to fit a used unit but they are difficult to find low mileage AND if the engines build date is before a certain point you are crazy if you don’t rebuild the problematic chain system to the later version and that gets expensive to do correctly.
  1. Dreaded fuel gauge and speedo failure
    By scotty33 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-08-2013, 02:17 PM
  2. Oil Pressure warning - have I the dreaded major failure!
    By new2vwa in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-04-2013, 06:44 PM
  3. Question Is this the dreaded injector failure?
    By BenR in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-08-2011, 03:35 PM
  4. Question What causes the dreaded injector failure
    By rapport25 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-07-2011, 08:23 AM
  5. Is it possible for BLB Oil Pump Chain Failure in a 2007 A6 2.0 tdi BRE Engine?
    By James1965 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-03-2011, 05:29 PM
