Thread: MK5 DSG non start from the key
Results 1 to 8 of 8
  1. MK5 DSG non start from the key
    Jul 2010
    Bradford, West Yorkshire
    As title guys,
    got a mk5 dsg in, the car will not turn via the key, if i apply a direct battery supply to the starter solenoid, it will fire up and drive perfect.
    all fuses and relays are fine.
    anyone come across this fault before.
  2. Re: MK5 DSG non start from the key
    Oct 2017
    London
    12 Post(s)
    Ignition switch failure? Very common in Mk5 Golfs, have you got Vcds to run a scan? Maybe something like this....
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 CA HW: 1K0 953 549 CA
    Component: J0527 051 0101
    Coding: 0000012
    Shop #: WSC 01392 785 00200
    VCID: 73B22FD0A7BF610FC73-8026
    4 Faults Found:
    00576 - Terminal 15
    012 - Electrical Fault in Circuit
    00883 - Ignition Switch (D) Terminal S
    00884 - Ignition Switch (D) Terminal X
    01744 - Ignition Switch Terminal P (D)
    1 1 0
  3. Re: MK5 DSG non start from the key
    Jul 2010
    i did have those fault codes so have replaced the switch with a new one and its still the same.
    i am not getting communication with the transmission control unit, but once started it communicates fine and drives perfect.
  4. Re: MK5 DSG non start from the key
    1841 Post(s)
    Which year and engine code?
  5. Re: MK5 DSG non start from the key
    Jul 2010
    hi crasher
    its a 58 registered with a bkd engine
    thanks
  6. Re: MK5 DSG non start from the key
    1841 Post(s)
    I think you are having a starter lock out command issue from the box, I can’t look deeper into it until Monday now. Does the gear lever select as it should?
  7. Re: MK5 DSG non start from the key
    Jul 2010
    it does when started. but with ignition on the selector is flashing and there is no footbrake symbol on the dash
  8. Re: MK5 DSG non start from the key
    1841 Post(s)
    If the dash gear indicator is flashing I think it will be a faulty Mechatronic unit so you need to have a code read done.
  1. Replies: 3
    Last Post: 15-08-2016, 09:21 AM
  2. Replies: 3
  3. Solved BLB engine too hard to start... but after starting the next start is normal..
    By matrixpt in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-05-2014, 11:51 AM
  4. Please Help On start up intermittent glow plug flashing non start engine fault garage flashes up
    By dazcheff in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-09-2012, 08:39 PM
  5. Won't start: faulty start valve?
    By Shaka1976 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-07-2010, 04:22 PM
