Thread: Vibration over 60mph
Results 1 to 9 of 9
  1. Vibration over 60mph
    May 2014
    United Kingdom
    Hi All,
    Suddenly i am getting front of the car vibration over 60mph. Very noticeable steering wheel also shakes. Changed all tyres, alignment done also traking. Wheel is 21inch talea. What can be the issues?
    Arrived: Audi A7 Quattro Black Edition 245 ps, 21 inch rotor. Tech pack. Phantom Black.
    Gone: AUDI A6 - 2011, DAYTONA GRAY, 2.7 TDI QUATTRO S LINE SPECIAL EDITION. MMI 3G. DVD PLAYER. 19 INCH.
  2. Re: Vibration over 60mph
    Apr 2010
    Surrey
    23 Post(s)
    Did your tyre fitter checked for buckled wheels?
    i would get balancing checked on another machine in case the balancing machine is out of spec.
  3. Re: Vibration over 60mph
    Dec 2009
    Dublin, Ireland
    25 Post(s)
    I have had several experiences over the years of poor workmanship on wheel balancing (in main dealers, but not Audi).
    Despite what they say about it all being computer controlled, a mate of mine in a business brought me through the process one day and it balance certain wheels properly can be tricky.
    In certain situations the skill/ commitment of the operator is critical, so find a recommended place and explain the problem, and request they balance it to zero, often thay have a tolerance. Ideally clean all the glue, muck, everything off first and start with a clean wheel.
    As previous suggested it could be a bent wheel...
    Worth swapping front to rear to see if this changes behavior.
  4. Re: Vibration over 60mph
    May 2014
    United Kingdom
    Did wheel balancing yesterday, and swapped wheel front to back. No damage on wheel. Will drive tomorrow and comeback with results.
  5. Re: Vibration over 60mph
    May 2014
    United Kingdom
    Nothing changed still vibrates. Booking in with audi for checking.
  6. Re: Vibration over 60mph
    Aberdeen
    63 Post(s)
    Any sign of the brakes getting hotter than expected? Could be a caliper or warped discs.
  7. Re: Vibration over 60mph
    May 2014
    United Kingdom
    Ok update on this. The tyre shop did wheel balancing with extra weight. Each wheel was over 130gram balance weight recommended was 30gram only. Audi fixed the problem doing proper wheel blanching.
  8. Re: Vibration over 60mph
    Apr 2010
    Surrey
    23 Post(s)
    Glad you got it sorted. Take the report back to the tyre shop and ask for a refund.
  9. Re: Vibration over 60mph
    Dec 2009
    Dublin, Ireland
    25 Post(s)
    Quote Originally Posted by kamark View Post
    Glad to hear you are sorted. It confirms again the rather disappointing reality that many places can't or do not bother to balance wheels properly. So we tolerate degraded ride quality, increased wear on components and reduced safety.
    It's just so important that you have someone trustworthy balance wheels (front & rear) to as close to zero as can be done. And don't believe the BS that "it's all done by the computer". Proper wheel balancing has a skill & experience factor.
    1 1 0
  1. HELP Car cut out doing 60mph now won't start
    By richardson86 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-08-2018, 09:07 PM
  2. Vibration above 60mph
    By AK88 in forum A7 - S7
    Last Post: 28-08-2017, 08:00 AM
  3. Whistle @ over 60mph
    By peacdun in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-04-2011, 03:02 PM
  4. Question Audi A4 Avant vibration at 60mph
    By Fodens in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-10-2010, 10:15 AM
  5. '02 A3 1.6 stuttering at 55-60mph
    By kevH in forum Audi A3 - Archive Topics
    Last Post: 26-08-2008, 10:56 AM
