Thread: Replaced front shock absorbers and coil springs now it creaks a lot mk6 golf
Results 1 to 10 of 13
  1. Replaced front shock absorbers and coil springs now it creaks a lot mk6 golf
    Mar 2009
    Hello I replaced the front suspension with new coil springs and shock absorbers also mount but now it creaks it’s was great for the first 2 weeks and just started ,sounds
    like the coil springs any ideas why it would do that thanks
  2. Re: Replaced front shock absorbers and coil springs now it creaks a lot mk6 golf
    28 Post(s)
    690 Post(s)
    Give us a list of the part numbers you fitted and message me the reg or VIN.
  3. Re: Replaced front shock absorbers and coil springs now it creaks a lot mk6 golf
    Mar 2009
    Hello the reg is fg60hzf. Wvwzzz1kzbw063617. So the front coil springs bought from smf eurocarparts 1k0411105aq Kyb springs ,the front shock absorber from gsf 1k0413031ac , just trying to find out the shockabsorber mounts I fitted
  4. Re: Replaced front shock absorbers and coil springs now it creaks a lot mk6 golf
    28 Post(s)
    690 Post(s)
    The OE spring number you quote is correct and should be ECP number 627446152 and a KYB RH3553.
    The dampers are VAG number 1K0 413 031 BF and Sachs
    312 267
  5. Re: Replaced front shock absorbers and coil springs now it creaks a lot mk6 golf
    Mar 2009
    Any idea what would cause the creaking ,does it in a straight line slightly but more so turning when the weight goes to the one side ,
  6. Re: Replaced front shock absorbers and coil springs now it creaks a lot mk6 golf
    28 Post(s)
    690 Post(s)
    Did you have the wishbones off?
  7. Re: Replaced front shock absorbers and coil springs now it creaks a lot mk6 golf
    28 Post(s)
    690 Post(s)
    No idea why this was closed, who did that?
  8. Re: Replaced front shock absorbers and coil springs now it creaks a lot mk6 golf
    Mar 2009
    No didn’t have the wishbones off and the shock absorbers are amtex
  9. Re: Replaced front shock absorbers and coil springs now it creaks a lot mk6 golf
    28 Post(s)
    690 Post(s)
    Never heard of Amtex, a quick Googling suggests they are Chinese. I would only fit Boge, Sachs, Monroe or TRW. If you fitted a damper equivalent to 1K0 413 031 AC then that is OK in theory as the correct 1K0 413 031 BF is a Boge 32-M74-A or a Sachs 312 267 as is the AC version.
  10. Re: Replaced front shock absorbers and coil springs now it creaks a lot mk6 golf
    Mar 2009
    Bought them from gsf not sure I don’t think that’s the creaking I did spray the bushes on the wishbone but made no difference could it be the spring just creaking
  1. Front SHock Absorbers - A Complete pain!
    By glowplug in forum Alhambra
    Last Post: 21-12-2015, 08:26 PM
  2. How to replace front shock absorbers?
    By Nimshoi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-11-2015, 05:07 PM
  3. How To Video: Replacing the front shock absorbers
    By Dr944S2 in forum Volkswagen
    Last Post: 13-10-2014, 07:15 PM
  4. New front shock absorbers
    By kunaalv in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-06-2010, 08:19 PM
  5. front shock absorbers
    By yvonne8261 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-02-2008, 01:27 PM
