Thread: Coolant leak
Results 1 to 10 of 10
  1. Coolant leak
    Jun 2019
    Kenya
    I have 2012 audi A6.my coolant level keeps going down.the car prompts stop engine and check coolant level...i keep topping the coolant .what the solution to this
  2. Re: Coolant leak
    1840 Post(s)
    Start by telling us what the engine is?
  3. Re: Coolant leak
    Jun 2019
    Kenya
    CHASIS -WAUZZ4G8CN104281
    MODEL-AUDI A6
    *CC -1984*
    YEAR-2012*
    PETROL
    My car details
  4. Re: Coolant leak
    1840 Post(s)
    So a Havana black type 4G2 07H with a CDNB engine, an NDL gearbox and built 20-12-11. What is a Singapore model car doing in Kenya? Which octane of fuel are you running it on? Is the engine warning light on and do you have any problems with the gear shift quality? You should get a code read done. These can loose water from the gearbox fluid cooling pump but also coolant can leak from the cooler into the ATF so you would need an Audi dealer to do an ATF glycol test.
  5. Re: Coolant leak
    Jun 2019
    Kenya
    no warning sign at all.it just gives warning when the coolant is low(stop engine and check coolant level).i have to top up every after one week.i imported from singapore
  6. Re: Coolant leak
    1840 Post(s)
    Which Octane fuel are you using?
  7. Re: Coolant leak
    Jun 2019
    Kenya
    unleaded extra
  8. Re: Coolant leak
    Jun 2019
    Cambridge
    Could be a leaking radiator, water pump or hose of worst case scenario a leaking head gasket. Would recommend to check these parts. If you find a leak, smell it. If it is a sweet smell it probably is coolant.
    You can try to use a stop leak, worth a try i would say.
  9. Re: Coolant leak
    1840 Post(s)
    Quote Originally Posted by Weloos View Post
    unleaded extra
    Which octane, RON or MON is that? Coolant seal additives block the heater matrix but I imagine in Kenya you don't use the heater much.
  10. Re: Coolant leak
    Jun 2019
    Wellingborough
    I had this on my last car and it was a water pump, could be something simple like a split hose mind (also had this)
  1. Coolant leak - Culprit is the Coolant inlet valve seal
    By inchshort in forum Q7 - 4M Forum - 2016 -
    Last Post: 06-01-2024, 08:48 PM
  2. 1.9TDI (BKC) Fuel Pump Leak & Coolant Leak.
    By DannyBoyGolf in forum Golf MK5 - 2004 - 2009
    Last Post: 16-07-2018, 10:51 PM
  3. Question Fuel leak? coolant leak?
    By J4G3D in forum Golf MK5 - 2004 - 2009
    Last Post: 30-11-2016, 08:34 PM
  4. Question Coolant leak from rear flange: Sourcing the coolant pipe?
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-09-2015, 11:36 AM
  5. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
