Thread: MFSW Fault code 01426
  1. MFSW Fault code 01426
    Jan 2013
    Hi Guys,
    My MFSW and paddle shift buttons have stopped working. The buttons are still illuminated, horn works, no airbag lights on, cruise control, steering wheel height adjustment, indicators etc work
    Removed the clock spring to do a continuity check across the ribbon and cables too and from the buttons themselves. All checked out good with no issues.
    With ignition on I get 11.5v feeding the buttons at the local 3 cable connection behind the airbag and around 8.5-9v coming out of the the buttons on the LIN bus cable ( not sure what voltage I should expect coming out off this cable?
    If I press any of the MFSW buttons with the mulitmeter on the LIN bus cable/ground the voltage doesn't change, not even sure it should change?
    I'm loathed to buy new buttons until I'm 100% sure that's where the problem lies.
    Any help on this would be greatly appreciated. These electrical gremlins can be a nightmare to track down!
    Cheers chaps
  2. Re: MFSW Fault code 01426
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    VCDS would be helpful ( or an equivalent good diagnostic tester) to check that each button responds on the diagnostics when depressed rather than guessing inputs and outputs without knowing any values. You would also get any current trouble codes.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: MFSW Fault code 01426
    Jan 2013
    Hi Alan.
    I've got VCDS mate, none of the buttons respond to being pressed, the only code on the car as of today when I cleared some older ones was the 01426. There doesn't seem to be any info available on how to test the buttons with regards to voltages/resistances that would indicate if the the buttons are operating as they should.
    Perhaps the fault lies elsewhere as the LIN bus signal goes back through clock spring ribbon then into the steering wheel control module, where it goes from there I have no idea.
    Any experience with this yourself?
  4. Re: MFSW Fault code 01426
    Jan 2013
    Is this not a common fault on Q7 guys?
  1. MFSW Buttons dead Fault 01426
    By dean warren in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-10-2017, 04:47 PM
  2. Help Please! MFSW Code rejected error 31: Request out of range
    By Arod_A4 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 02-06-2014, 08:12 PM
  3. Question MFSW can you add the multi function controls to a non MFSW ??
    By Alann84 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-01-2012, 09:36 PM
  4. Can I swap MFSW for flat bottom MFSW
    By Two_Stripes in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-05-2011, 10:20 PM
  5. mfsw code ?
    By richiemac in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-04-2010, 09:46 AM
