Thread: A4 B6 1.8T FWD 5-speed manual HFD Gearbox / Front differential knock (very bad)
  1. A4 B6 1.8T FWD 5-speed manual HFD Gearbox / Front differential knock (very bad)
    May 2019
    I got a very bad knock when I take off from stationary, as I release the clutch, its really annoying, sounds like an old truck.
    I recorded a few videos to show you as accurately as possible:
    Clutch release: A4 B6 1.8t knocking rattling on clutch release - YouTube
    Differential knock: Audi A4 B6 FWD gearbox / front differential knock - YouTube
    Is there a separate front differenctial in our FWD 5-speed manual version or it comes all together with the gearbox?
    Does the front diff have a separate oil chamber outside the gearbox, and does it need separate oil change or its the same chamber as the gearbox? Would some nice thicker oil help at all?
    I just changed oil in the gearbox, didnt help..
    I see whats coming but I just dont want to believe that I have to replace the whole gearbox , just spent a small fortune on timing belt and service, new clutch etc, I am trying to find an excuse or other explanation.
    Any ideeas? Cheers
    A4 B6 2004 1.8T Stage 1+ S-Line Limited Edition
  2. Re: A4 B6 1.8T FWD 5-speed manual HFD Gearbox / Front differential knock (very bad)
    1841 Post(s)
    The diff is integral but when the box was replaced, were all bolts replaced as what you have sounds like something is loose.
  3. Re: A4 B6 1.8T FWD 5-speed manual HFD Gearbox / Front differential knock (very bad)
    May 2019
    I didn't had the box replaced, just the clutch, and for the clutch new bolts were used, but thats all I know about the bolts... The mechanic swares down that he tightened everything.
  4. Re: A4 B6 1.8T FWD 5-speed manual HFD Gearbox / Front differential knock (very bad)
    1841 Post(s)
    You have to remove the box to do the clutch, he may well have tightened everything but a large number of the bolts/nuts are one time only and this probably was not the first time the bolts have been out so they can stretch or even snap.
  5. Re: A4 B6 1.8T FWD 5-speed manual HFD Gearbox / Front differential knock (very bad)
    May 2019
    Well, we will find out soon, I found a gearbox in good condition for a good deal, so will get it replaced this week.
    I am thinking to get new set of bolts though, any ideea where to find them?
  6. Re: A4 B6 1.8T FWD 5-speed manual HFD Gearbox / Front differential knock (very bad)
    1841 Post(s)
    Yes, the only source is the main dealer or TPS if your chap has an account.
  7. Re: A4 B6 1.8T FWD 5-speed manual HFD Gearbox / Front differential knock (very bad)
    May 2019
    Thanks mate
  1. How To Mk4 gearbox 6 speed manual
    By Oilyrag in forum "How To" Guides
    Last Post: 05-02-2018, 07:21 PM
  2. Question A6-C5 6 speed manual gearbox mounts
    By JMR1 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-10-2016, 10:58 AM
  3. A3 6 Speed Manual Gearbox Oil Change
    By dumpee in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-09-2012, 12:41 PM
  4. A6 1.9 TDI 5 speed manual gearbox
    By MitchW in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-02-2012, 06:10 PM
  5. Front suspension Knock over speed bumps
    By Arty in forum Touran - Sharan - Caravelle
    Last Post: 01-04-2010, 01:23 AM
