Thread: overheating and other issues
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: overheating and other issues
    1841 Post(s)
    The controller is in the large fan and there are two versions 220 or 300 watt. The problem is the controller can be damaged by a faulty second fan so you must change both. The main fan is £240 from VW and the second is £205 BUT both are easily available aftermarket for much less.
  2. Re: overheating and other issues
    Jan 2019
    Thanks crasher, so not worth just changing the controller then? and how do I know which version I have of the large fan?
  3. Re: overheating and other issues
    1841 Post(s)
    The numbers are on the fans, there are two versions of small fan as well.
  4. Re: overheating and other issues
    Jan 2019
    Nothing is simple on these cars is it!
  5. Re: overheating and other issues
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    Quote Originally Posted by jasst View Post
    You could say that!!
  6. Re: overheating and other issues
    Jan 2019
    Interestingly I was looking at the handbook for an entirely unrelated reason and I read the page regarding the gauges, apparently the normal operating range is up to 120degC, and the warning light will not come on till that temp is exceeded, so I may have been panicking for nothing! still seems to be a very high temp for the engine to be running at, but what do I know!
  7. Re: overheating and other issues
    #17
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    Yes mine says that as well, but 120°C is definitely not normal unless you are towing a caravan up a steep hill in the hottest place on earth!
    In the UK a car should never exceed 90 maybe going up to 100 tops if you're pushing it.
  1. 3TDi starting issues/ dying issues
    By 20vcqdriver in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-05-2014, 10:01 AM
  2. Please Help Fans not working and causing a number of issues (overheating/No Air Con)
    By Simon West Oz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-04-2014, 10:08 PM
  3. S6 c5 overheating
    By w55ksy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-03-2014, 10:57 AM
  4. 1.8t Overheating
    By Lockstockfrog in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-12-2012, 11:20 PM
  5. Overheating - Water pump issues
    By guyg in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-06-2009, 02:08 PM
