Thread: AllRoad 2005 collapsed front suspension
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: 2006 A6 allroad Quattro collapsed suspension
    Jan 2019
    Suffolk
    9 Post(s)
    So now this is in the 2001-2004 forum, hopefully you have noticed this other thread: Allroad Air Suspension Problems
    The sudden failure seems a bit odd but struts (bags) which start to leak and compressors that wear to the point of not being able to raise the suspension before the control unit gives up are discussed at some length. You can test for leaks by parking, engaging jacking mode, measuring the height, leaving it a good while, for example overnight, and measuring again. Compressors can often sorted out with one of two kits from bagpipingandy, either a piston ring or piston ring+cyclinder so much cheaper than a new compressor.
  2. Re: 2006 A6 allroad Quattro collapsed suspension
    1840 Post(s)
    The date of this section could do with changing to 2005 as normal 4B production ended in January 2005 BUT the AllRoad ended in August.
  3. Re: AllRoad 2005 collapsed front suspension
    Jun 2019
    Braintree
    Well 48hrs later and it's still up where I left it.got no idea what happened to cause it to drop unless it's something to do with the steering left on full right turn.owner now going to sell as just brought a golf 3 times more economical on fuel she's going through a divorce at mo and very short of money I'll end this thread now thanks for all the help and advice.
  1. 2005 allroad front brakes issue
    By quattrogary in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-07-2017, 10:29 PM
  2. 2005 2.5tdi allroad front pad size
    Last Post: 02-05-2017, 02:59 PM
  3. a6 allroad front suspension rattle
    By chris.d in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-02-2016, 06:23 PM
  4. Allroad Front Suspension Parts
    By stewartbuckland in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 24-01-2009, 08:04 PM
