Thread: Number plate light/lens
  1. Number plate light/lens
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    Hi all,
    I haven't posted in a while as since getting the brakes and timing belt changed, life in the Passat has been problem free!!
    That is until the "bulb failure" lamp came on again, and this time it wasn't the headlamp bulbs since I'd just replaced those with Osram Night Breakers. This time I have tracked it down to one of the number plate lights, more specifically the right (O/S) one. But the bulb itself is fine, it is one of the terminals that has burnt/corroded and no longer gives the bulb a proper connection.
    OK I thought, lets just order a new lens as it is only a small plastic part... Well after searching on eBay the closest thing I could find was this: VW PASSAT B6 2005 - 2008 2X NEW REAR NUMBER PLATE LIGHT LAMPS LEFT + RIGHT | eBay
    HOWEVER, I don't need two of them as the N/S is still perfectly fine, and maybe I'm being overly parsimonious but I think £13.99 is a bit expensive for two plastic lenses, not including the assembly.
    I haven't gone into my local parts store but that is almost a waste of time as they will probably only sell them in pairs as well, or will sell individually but the price would make the £13.99 pair seem cheap.
    I presume it is a relatively common fault as the plastic has actually yellowed at one end where the terminal is damaged, and almost broke as I took it out.
    Please can someone let me know if the above linked eBay listing is my best/cheapest bet, or if there is somewhere I can get just the one lens that I require.
    Thanks!!
  2. Re: Number plate light/lens
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    The item you have linked is 2 full units with bulbs but in white plastic as they are not OE style.
    This is OE style for one full light unit
    https://rover.ebay.com/rover/0/0/0?m...2F264230304267
    Cheaper still
    https://rover.ebay.com/rover/0/0/0?m...2F323785856915
    They clip in and the lenses are not normally available separately so sold as complete replacement units. £12 to £20 each isn't so bad for genuine parts therefore.
    Mad Mitch
  3. Re: Number plate light/lens
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    Thanks, but even those don't match what are currently on the car. I will attach a picture that maybe shows more, but there doesn't seem to be a unit that can be easily removed, rather the lenses themselves just "slot" into place and are held in by two screws. I presumed only the plastic part is what I needed as that contains the terminals that have corroded on my old one.
    I have managed to find an eBay listing with just one lens that exactly matches what is currently fitted (VW PASSAT B5 B6 TOURAN TRANSPORTER T5 MULTIVAN NUMBER PLATE LAMP LIGHT 3B5943021 1002111305684 | eBay), but that does work out more expensive per lens than buying the pack of two.
    It is also worth mentioning that it is an estate which I think does make a difference as the saloons had a different style of light from what I have managed to piece together.
  4. Re: Number plate light/lens
    Jan 2012
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by jmurray01 View Post
    Ah estates are slightly different, and have the same unit as the T5. Part number 3B5943021E which was discontinued in 2012 but still available to buy whether genuine or aftermarket.
    https://www.ebay.co.uk/itm/VOLKSWAGE....c100930.m5375
    Mad Mitch
  5. Re: Number plate light/lens
    Oct 2018
    Buckie, Scotland
    17 Post(s)
    That explains it then! Thanks, I will order one of those.
  1. number plate light's
    By big jase in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-05-2011, 06:36 PM
  2. Number plate lens
    By 12bamf in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-05-2011, 03:38 PM
  3. A6 C5 number plate surround/ fog light lens
    By paddymm in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-05-2010, 09:00 PM
  4. Boot lid light and number plate light panel
    By Walesgbn in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 21-01-2009, 08:33 PM
  5. Number plate light
    By shd01 in forum Touran - Sharan - Caravelle
    Last Post: 21-11-2006, 10:43 AM
