Thread: Front brake pad sensor wiring
  1. Front brake pad sensor wiring
    Jun 2019
    pontypool gwent
    Hi all my son has a 2007 a3 tdi 170bhp sline bmn engine, the problem that he has is the abs light come on took wheel off had a look could see the problem straight away wire had broke on main loom and this works the abs as well as the brake wear been on this site found a thread on here with the same problem and pics the thread being posted by a member called TimA6QSline 21/04/2017, i understand that this is a old post the pic shows is the loom that i am looking for i think that the part no is1K0927903 b for the uk would anybody have any idea's on the part number also where i could get this part from thanks for all your time and helpAUDI FRONT LEAD.jpg
  2. Re: Front brake pad sensor wiring
    Near Blackpool
    48 Post(s)
    Call your local TPS. They can find it from your reg
  3. Re: Front brake pad sensor wiring
    Jun 2019
    pontypool gwent
    Great stuff give tham a call, did not think they would do it as it is part of a loom thanks for your help.
  4. Front brake pad sensor wiring
    Near Blackpool
    48 Post(s)
    My local TPS will get the diagrams up and see if the looms are separate etc really helpful guys
  5. Re: Front brake pad sensor wiring
    Jun 2019
    pontypool gwent
    Thanks ever so much for your help, my tps is going to be cardiff give them a ring.
  6. Re: Front brake pad sensor wiring
    Jun 2019
    pontypool gwent
    Just rang tps got the loom, all in £50 brill gave them the part code right code apart from last letter being a r can't thank you enough for your help
  7. Re: Front brake pad sensor wiring
    Near Blackpool
    48 Post(s)
    No worries the last letter is the revision so as they improve them the letters move on. Glad you’re sorted! It’s what this forum is for
    By TimA6QSline in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 21-03-2023, 02:26 PM
  2. ABS Sensor wiring removal front right
    By jtilling in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-01-2018, 02:52 PM
  3. Question Front Brake Pad Sensor
    By Jockeyblade in forum Golf MK4 - 1999 - 2004
    Last Post: 31-01-2012, 04:40 PM
  4. Maf sensor wiring
    By mcurrier in forum Alhambra
    Last Post: 18-02-2010, 11:00 PM
  5. Airbag front crash sensor wiring!
    By noddyr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-09-2009, 03:30 PM
