Thread: A6 2006 Quattro vibration
Results 1 to 10 of 15
  1. A6 2006 Quattro vibration
    Jun 2019
    Australia
    Evening,
    i have a 2007 quattro 4.2 avant with air suspension.
    125k miles.
    bought it with a vibration through the seat but struggling to cure it. vibration occurs at approx 65-75mph. over 75mph and it goes
    have had wheels balanced with normal and roadforce balancing.
    Have tried 2 sets of wheels/tyres.
    have replaced rear discs, which i thought helped but it soon reappeared.
    i *think* (but cannot guarantee) it does reduce if i put into neutral when at this speed.
    suspension components look to be okay.
    I think it needs a 4 wheel alignment - is it possible this might cause a vibration at speed?
    i don't think its had a gearbox or diff oil change.
    my thoughts....
    4 wheel alignment?
    control arms/wishbones?
    sticking caliper piston?
    propshaft?
    driveshaft?
    diff?
    gearbox?
    flywheel?
    engine mount?
    tyres - think i have ruled out.
    wheel balancing - think i have ruled out.
    wheel buckle - think i have ruled out.
    apart from the vibration it goes well. just annoying when travelling at highway speed.
    any suggestions on where to start?
    cheers.
  2. Re: A6 2006 Quattro vibration
    Aberdeen
    63 Post(s)
    Try and get it scanned for faults. Any chance it could be a misfire from old injectors? Also could be the torque convertor. I would have thought the most likely candidate was the tyres / wheels or driveshaft / CV joint.
  3. Re: A6 2006 Quattro vibration
    Jun 2019
    Australia
    thanks for reply. scanned with VCDS and no faults.
    i've tried dropping down a couple of gears at the same speed to see if its RPM dependent or speed dependent - but not drawn a conclusion on that...
    i never though of torque converter or CV joint.
    think i've ruled out tyres and wheels as have swapped over to 2 sets with no difference and replaced one set of cheap ditchfinders with some better mid range and had wheels balanced twice.
    will try and get a better look underneath at the weekend.
  4. Re: A6 2006 Quattro vibration
    Jun 2019
    Australia
    just to confirm
    vibration does not occur through acceleration, only once at 65-75mph.
    is felt through seat.
    trying to see if it occurs in 4th and 5th gear at this speed to then determine if speed or RPM linked.
    suppose that will then rule in or rule out some of the items on here and point more towards engine/gearbox or diff/driveshaft.
  5. Re: A6 2006 Quattro vibration
    1836 Post(s)
    I would check that the radial run out coloured markings on the rear flanges are aligned.
  6. Re: A6 2006 Quattro vibration
    Jun 2019
    Australia
    thank you. is this the connection from the prop to the rear diff?
  7. Re: A6 2006 Quattro vibration
    Jun 2019
    Australia
    Page 2
    are these the markings?
    thank you in advance.
  8. Re: A6 2006 Quattro vibration
    1836 Post(s)
    Yes.
  9. Re: A6 2006 Quattro vibration
    May 2008
    26 Post(s)
    Any significant rattle from the engine when you start from cold? A failed timing chain tensioner can introduce a marginal timing difference between the two sides of the engine, which resonates at a certain speed. Mine used to do it at about 62mph but after fixing timing chain tensioner, it went away.
    2007 A6 Allroad 3.2 FSI Tiptronic (C6 pre-facelift) - left hand drive
  10. Re: A6 2006 Quattro vibration
    Jun 2019
    Australia
    Quote Originally Posted by 54A4Avant View Post
    thank you for the reply. this is interesting.
    no noticeable rattles, but very interesting to note.
    it is a hydraulic tensioner buried somewhere near the rear bottom of the engine?
  1. A6 Quattro Rumble/Vibration.
    By Stuart Piper in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-05-2013, 07:06 PM
  2. C6 2l tfsi 2006 vibration.....gulp
    By Seven Heaven in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-02-2013, 11:25 AM
  3. Replies: 0
    Last Post: 14-03-2012, 10:51 PM
  4. A3 quattro vibration
    By alfiestock in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-11-2011, 05:40 PM
  5. Question Quattro Vibration
    By steveb5avant in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-11-2008, 11:54 PM
