Thread: A6 2006 Quattro vibration
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: A6 2006 Quattro vibration
    May 2008
    26 Post(s)
    I’ll let someone else answer as I don’t know the 4.2 engine (mine is a 3.2). Timing imbalance can be read within blocks 93 of engine ECU module, so you can check this without any guesswork being required once you have vcds or an xtool vag401 reader.
    2007 A6 Allroad 3.2 FSI Tiptronic (C6 pre-facelift) - left hand drive
  2. Re: A6 2006 Quattro vibration
    1840 Post(s)
    The BAT and BVJ cam drive systems are scary, four chains and all the things that go with them. They wear badly on LongLife service regimes and if rebuilding preventatively you can throw £6K at a BAT chain drive.
  3. Re: A6 2006 Quattro vibration
    Jun 2019
    Australia
    Quote Originally Posted by 54A4Avant View Post
    thank you. i'll have a look on VCDS later. i've not noticed any codes or rattles from the engine, but will check this this ecu module.
  4. Re: A6 2006 Quattro vibration
    Jun 2019
    Australia
    update...
    over the weekend i managed to put some kilometers in.
    also managed to coast and turn off engine whilst at speed which indicated vibration is still there, which leads me to think its
    * driveshaft
    * cv joint
    * disc/rotar
    * caliper
    * diff
    * propshaft
    * bushes.
    also noticed that 2 of the discs are quite warm even when not thrashed, which is leading me to think it could well be caliper or disc.
    i'm more relieved its not engine or gearbox as the vibration is still there when off and in neutral.
    will have another look at each of these components this weekend.
  5. Re: A6 2006 Quattro vibration
    Jun 2019
    Australia
    rewound rear calipers and issues has gone, so assume it must be sticking caliper.
  1. A6 Quattro Rumble/Vibration.
    By Stuart Piper in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-05-2013, 07:06 PM
  2. C6 2l tfsi 2006 vibration.....gulp
    By Seven Heaven in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-02-2013, 11:25 AM
  3. Replies: 0
    Last Post: 14-03-2012, 10:51 PM
  4. A3 quattro vibration
    By alfiestock in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-11-2011, 05:40 PM
  5. Question Quattro Vibration
    By steveb5avant in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-11-2008, 11:54 PM
