Thread: EGR and EGR error data from TORQUE via XTRONS ODB .....interpretation please?
Results 1 to 10 of 17
  1. Question EGR and EGR error data from TORQUE via XTRONS ODB .....interpretation please?
    Apr 2019
    I have recorded the EGR % value (presumably some measure of the opening of the EGR valve)
    along with EGR Error (preumably the difference between where the valve SHOULD be and where
    it was (??) for a nice motorway drive Southampton to Southend (vehicle running at normal temp)
    2011 2.0TDI Passat/ 3C/ CFFB with 100k on the clock
    The data was captured using TORQUE running on a mobile capturing via bluetooth the data from a XTRONS ODB adaptor
    There is a LOT of information BUT knowing that I am experiencing juddering around 1750-2000 rpm I started looking at the data
    Now the full size plots are here: EGR Plots3 | John C Bullas BSc MSc PhD MCIHT MIAT | Flickr
    These are reduced in size
    EGR vs. RPM
    Engine Load versus EGR error
    Engine RPM versus EGR Error (getting closer)
    Now this is showing where the WORST errors are happening
    I would like to take learned counsel on this data storm!
    What Can I learn, what does it tell me
    19,730 data points
    Regards
    Dr B
  2. Re: EGR and EGR error data from TORQUE via XTRONS ODB .....interpretation please?
    21 Post(s)
    627 Post(s)
    Typical EGR valve failure, new number 03L 131 512 DQ at 359.35 plus gaskets and around five hours in the air to fit.
  3. Re: EGR and EGR error data from TORQUE via XTRONS ODB .....interpretation please?
    Apr 2019
    It is worst at low levels of engine load and virtually unnoticeable during hard acceleration
  4. Re: EGR and EGR error data from TORQUE via XTRONS ODB .....interpretation please?
    21 Post(s)
    627 Post(s)
    If the light is coming on with an EGR range/performance code it will need replacing.
  5. Re: EGR and EGR error data from TORQUE via XTRONS ODB .....interpretation please?
    Apr 2019
    No fault codes via ODB and no dash warning lights
  6. Re: EGR and EGR error data from TORQUE via XTRONS ODB .....interpretation please?
    21 Post(s)
    627 Post(s)
    When you said “EGR error” I assumed you had a fault code.
  7. Re: EGR and EGR error data from TORQUE via XTRONS ODB .....interpretation please?
    Apr 2019
    I have these 2 faults but I don't have a means to decode them
    2 Faults Found:
    4871 -
    - 07 [032]
    Intermittent - Not Confirmed - Tested Since Memory Clear
    4891 -
    - 1B [032]
    Thus I am none the wiser
    The judder is coincident with the worst EGR error log in TORQUE
    John
  8. Re: EGR and EGR error data from TORQUE via XTRONS ODB .....interpretation please?
    21 Post(s)
    627 Post(s)
    They will be 004871 and 004891, I will have a look tomorrow if I get chance but I am upto my neck in it covering for holidays. I am not used to having to actually work these days, it won’t do!
  9. Re: EGR and EGR error data from TORQUE via XTRONS ODB .....interpretation please?
    Apr 2019
    4891-P0403 - EGR Valve N18
    Malfunction Open Circuit
    4871 - Exhaust Gas Recirculation Cooling Valve Control
    Argh!
  10. Re: EGR and EGR error data from TORQUE via XTRONS ODB .....interpretation please?
    May 2012
    Somerset
    220 Post(s)
    I had this on a mid 90's petrol turbo , couldn't understand why the light throttle, low rpm , caused a baby kangaroo .
    Older cars , simpler fix , a bolt in a vac line !
    All these modern cars are tosh , planned obsolescence parts expensive and buried deep when they don't have to be so labour is up . Replacing the part now never guarantees it will last the life of the car .
    I'm still having fun with an drive by wire throttle body fault code despite a new throttle body on a newer German car .
    Is yours a B7 Dr B ?
  1. Xtrons DAB PX71MTVDAB
    By justincase in forum In Car Entertainment
    Last Post: 21-12-2015, 12:44 PM
  2. Question 1.6sr running issues. Torque Data
    By scottydogwoof in forum Beetle 2000-
    Last Post: 05-08-2015, 04:51 PM
  3. MMI+ Nav Google Earth error: "Not Enough Data in Memory"
    By belly buster in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-02-2014, 08:28 PM
  4. Important Torque setting Data sheet VW golf 4
    By nathancrowster in forum Golf MK4 - 1999 - 2004
    Last Post: 26-08-2009, 07:52 PM
  5. torque setting data sheet for VW golf 4 1600cc 1999 Main Bearings
    Last Post: 24-11-2008, 08:58 PM
