Thread: Humming noise?
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Humming noise?
    Oct 2018
    York
    9 Post(s)
    Every time I turn left there is a sort of drone/hum coming from front right wheel area...could this be the bearing? I jacked the car up and tried to rock the wheel as they would at MOT, but no movement discernible. Anyone have an idea what this would be? Car is s Golf MkV 2.0tdi.
  2. Re: Humming noise?
    1840 Post(s)
    You will never see any free play in these and yes the do fail BUT also rear ones can sound like the front and are more prone to going AND the rear tyres on the Golf 5 platform can cause the same noise.
  3. Re: Humming noise?
    Oct 2018
    York
    9 Post(s)
    That's interesting, thanks. At times I have thought the noise was from the rear, so I suppose we'll see, come MOT in a few weeks. I've had a look at both front and rear replacement procedures, seem to be pretty straightforward jobs. Thanks again
  4. Re: Humming noise?
    Oct 2018
    York
    9 Post(s)
    Meant to ask - is there a way of determining bearing wear, if the wheel-rocking test doesn't show anything?
  5. Re: Humming noise?
    1840 Post(s)
    The noise when spinning it off the deck, it is an MOT failure now, one of my techs Golf 5 failed for it a week or so ago.
  6. Re: Humming noise?
    1840 Post(s)
    I have just done one on an A3 8P which is the same, the worst bit is the M18 XZN bolt, 180Nm+180 degrees...
  7. Re: Humming noise?
    Oct 2018
    York
    9 Post(s)
    Is that the central/hub bolt?
  8. Re: Humming noise?
    Oct 2018
    York
    9 Post(s)
    Did a test yesterday, span both front wheels with them up in the air - couldn't detect any noise or roughness at all. Have to move to the rears! Though I did find that the ns cv gaiter had no retaining band, with the result that the driveshaft outer bearings have been exposed to god knows what for god knows how long. Don't you just hate former owners...
  9. Re: Humming noise?
    1840 Post(s)
    Quote Originally Posted by dekhelia View Post
    yes
  10. Re: Humming noise?
    Oct 2018
    York
    9 Post(s)
    Had a look at the bolt...what on earth d'you use to get it off, some kind of giant Allen key?
  1. New Owner - Humming Noise Please Help!
    By Tommyj1980 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-05-2013, 12:46 PM
  2. Humming Noise
    By Marco 35 in forum Golf MK5 - 2004 - 2009
    Last Post: 13-01-2011, 10:36 PM
  3. Please Help NS Front Humming noise
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-06-2009, 10:42 PM
  4. help with humming noise
    By JAMEST5 in forum The Commercial Range
    Last Post: 30-01-2009, 01:27 AM
  5. T4 humming noise
    By Black Angus in forum The Commercial Range
    Last Post: 14-01-2008, 07:51 PM
