Thread: No1 cam lobe worn
  1. No1 cam lobe worn
    Jun 2019
    As the title says, No1 cam lobe is worn, the first lobe behind the timing belt. The car is a 58plate 2lt TDI Pwb engine. The rocker cover gasket was being replaced and the machanic noticed 2 flat points along the long sides of the lobe, one in each side, then on the "top" of the lobe you can feel a grove but it doesn't travel all the way round the lobe.
    What could possibly cause this, the machanic is stumped, I can't help because I don't know the history of the car it's been service up to 88k, the car has done 94k. The service history is first service by Audi at 18k, then 29k-71k 3 services by the same non Audi garage, 71k-87k 2 services non Audi garage. Long life service? Timing belt and water pump done at 76k.
    The only other really unusual thing of note is, I've had to replace all 3 engine mounts, the front mount just needed the rubber, but the left&right ones were "smashed" on the bottom of the mounts, again I don't know why or how.
    Any advice anyone can offer would be greatfully received
  2. Re: No1 cam lobe worn
    27 Post(s)
    652 Post(s)
    Could you private message me the REG?
  3. Re: No1 cam lobe worn
    27 Post(s)
    652 Post(s)
    BPW engine....yes it is a very common problem on the 8v PDTDI and the next thing you know will be a horrendous hammering noise when the cam eats through the lifter. The cause is the oil used over too long a period.
    If you don't fit new rocker arms, this can happen to the new cam which is not covered under any companies warranty unless you have proof the rockers were new.
  4. Re: No1 cam lobe worn
    Jun 2019
    Thank you so much for the replies, especially the description and pictures, I shall certainly be showing the machanic the pictures.
  1. Pirelli P7 235/40 R18 hardly worn
    By vwv12 in forum Wheels and Tyres
    Last Post: 29-08-2011, 10:27 PM
  2. how to tell if flywheel is bad or worn or whatever??
    By nickeym1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-02-2011, 10:10 AM
  3. Mk3 GTi worn rear end
    By JayB5UK in forum Golf MK3 - 1993 - 1999
    Last Post: 15-01-2010, 05:06 PM
  4. cv boot worn?
    By twofoot in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-07-2009, 12:07 AM
  5. worn tyres
    By barney2 in forum Wheels and Tyres
    Last Post: 22-07-2008, 02:28 AM
