Thread: DSG box does not hold car stationary when in P
Results 1 to 8 of 8
  1. DSG box does not hold car stationary when in P
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I am working on a 2011 Golf to raise some money for charity and it has a peculiar problem. When in Park, the car can roll in both directions. There are no fault codes. I am not sure where to start so any help will be useful. Its a CAVD engine with a MLD gearbox and only 37,000 miles.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  2. Re: DSG box does not hold car stationary when in P
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I assume that I need remove the gearbox cover from the engine compartment at the top of the gearbox. I think the cover is itself the parking lock, but not sure what I should be looking at.
    I will start the job tomorrow morning.
  3. Re: DSG box does not hold car stationary when in P
    Aug 2007
    Hook Hampshire
    21 Post(s)
    0AM 321 219 F 321-062 parking lock operating mechanism
    I am assuming the above part has broken or is bent. If broken I wonder where the broken part will be. In the gearbox??
  4. Re: DSG box does not hold car stationary when in P
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I finally got a new Parking lock (was on back order) for the Golf and on removing the old one, the old and new parts look identical with nothing amiss with the old part, so I am struggling to establish whether the existing part is faulty. Anyone have any ideas.
  5. Re: DSG box does not hold car stationary when in P
    1840 Post(s)
    Fit the new part and see what happens.
  6. Re: DSG box does not hold car stationary when in P
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Thanks C. Solution found. I did not try the new part despite having taken it out of its seal bag to compare it with the old one. I hate doing things without understanding what I am trying to find out what is wrong. So I istalled the old one again and started moving the gearshift lever on the gearbox without the cable being connected. The gearbox locked! I then noticed that the cable has an adjuster and the sliding part of the adjuster was loose. I then re-attached the cable in the lock position and tightened the nut. All was well.
    Now the interesting part. The nut was tight to turn, and I had to turn it a few times to tighten the slider on to the cable. So how did the nut get loose. I was told that this fault happened recently.
    I wonder if TPS will take the part back?
  7. Re: DSG box does not hold car stationary when in P
    1840 Post(s)
    I doubt it, special order and you opened the bag. I can sometimes get them to bend but I do spend a huge amount with them.
  8. Re: DSG box does not hold car stationary when in P
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Thanks Crasher. If you need the part, its yours. Let me know and I will post it to you. Alternatively I will drop it off when I am next in your area. SOAM321219F. it supercedes the part with E on the end of it.
  1. Question MK4 1.9 TDI Judder / Shudder when Stationary?
    By nomorebigideas in forum Golf MK4 - 1999 - 2004
    Last Post: 05-10-2015, 03:53 PM
  2. S-tronic when stationary
    By Rsheen in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 22-01-2013, 12:40 PM
  3. A6 tdi '06 Unstable rev while stationary
    By mattq in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-12-2010, 09:25 PM
  4. vibration when stationary
    By brian harrison in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-09-2009, 12:39 AM
  5. Juddering when stationary
    By mpm1987 in forum Golf MK5 - 2004 - 2009
    Last Post: 30-01-2009, 02:58 PM
