Thread: Battery light illuminated erratically for several miles
  1. Battery light illuminated erratically for several miles
    somerset
    8 Post(s)
    Hi all, my wife was driving the A4 1.8T Quattro BEX code when the battery light illuminated, it went out after a few seconds, but did this several times in a 10 mile journey.
    I have driven the car for 70 odd miles and it's not come back on, I replaced the battery last year and it had a new alternator clutch fitted about 60k miles ago.
    i have not checked anything yet, but as we are driving down through France this summer I don't really fancy the battery light coming on then!
    Any ideas as as to where to look first?????
    thanks. Rhen.
  2. Re: Battery light illuminated erratically for several miles
    scotland
    39 Post(s)
    Check the small single wire is tight and secure.
    Sent from my ANE-LX1 using Tapatalk
  3. Re: Battery light illuminated erratically for several miles
    scotland
    39 Post(s)
    Also check the single wire hasn't rubbed through the insulation and earthing somewhere.
  4. Re: Battery light illuminated erratically for several miles
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Alternator belt tension also
    A6 2.4 SE (2000)S3 1.8T (2001)80 Coupe 2.3 (1991)
    A3 1.8T sport (1997)A4 3.0 QST (2002)
    80 Coupe 2.6S (1995)A4 Cab 2.4 sport (2002) Another 2.6 '95 coupe in byzanz purple
    '88 type 89 90 saloon kv 5 pot A4 1.8T 2001
  5. Re: Battery light illuminated erratically for several miles
    somerset
    8 Post(s)
    Right, had a quick look today and something sounds a little rough, not bad, but not quite as quiet as it should be, as I also have an A4 cab, I used a stethoscope (screwdriver to the ear) and both the alternator and the tensioner arm sound rougher on the Quattro than the cab. For ease I am going to swap over the tensioner first, obviously checking the pulley bearing first, then if that does not change anything I will swap alternators which have identical part numbers, a process of ilimination, perhaps the tensioner pulley was starting to seize up causing the light to come on.........let's see how the swapping goes......
  6. Re: Battery light illuminated erratically for several miles
    somerset
    8 Post(s)
    All sorted now, replaced the alternator and all ok now.
  1. Esp light illuminated
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-12-2012, 09:34 PM
  2. Illuminated Hazrd light switch
    By qa15ar in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-08-2011, 04:59 PM
  3. No AirCon + No Fans + ECON light illuminated
    By Formy in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 31-05-2011, 04:49 PM
  4. Brake warning light Illuminated
    By a4suction in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-03-2011, 11:54 AM
  5. Emissions light illuminated on dashboard
    By meathead in forum Golf MK4 - 1999 - 2004
    Last Post: 19-07-2008, 03:39 PM
