Thread: Battery light illuminated erratically for several miles
  1. Battery light illuminated erratically for several miles
    Jul 2007
    somerset
    8 Post(s)
    Hi all, my wife was driving the A4 1.8T Quattro BEX code when the battery light illuminated, it went out after a few seconds, but did this several times in a 10 mile journey.
    I have driven the car for 70 odd miles and it's not come back on, I replaced the battery last year and it had a new alternator clutch fitted about 60k miles ago.
    i have not checked anything yet, but as we are driving down through France this summer I don't really fancy the battery light coming on then!
    Any ideas as as to where to look first?????
    thanks. Rhen.
  2. Re: Battery light illuminated erratically for several miles
    scotland
    39 Post(s)
    Check the small single wire is tight and secure.
    Sent from my ANE-LX1 using Tapatalk
  3. Re: Battery light illuminated erratically for several miles
    scotland
    39 Post(s)
    Also check the single wire hasn't rubbed through the insulation and earthing somewhere.
  4. Re: Battery light illuminated erratically for several miles
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Alternator belt tension also
  5. Re: Battery light illuminated erratically for several miles
    Jul 2007
    somerset
    8 Post(s)
    Right, had a quick look today and something sounds a little rough, not bad, but not quite as quiet as it should be, as I also have an A4 cab, I used a stethoscope (screwdriver to the ear) and both the alternator and the tensioner arm sound rougher on the Quattro than the cab. For ease I am going to swap over the tensioner first, obviously checking the pulley bearing first, then if that does not change anything I will swap alternators which have identical part numbers, a process of ilimination, perhaps the tensioner pulley was starting to seize up causing the light to come on.........let's see how the swapping goes......
  6. Re: Battery light illuminated erratically for several miles
    Jul 2007
    somerset
    8 Post(s)
    All sorted now, replaced the alternator and all ok now.
  1. Esp light illuminated
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-12-2012, 09:34 PM
  2. Illuminated Hazrd light switch
    By qa15ar in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-08-2011, 04:59 PM
  3. No AirCon + No Fans + ECON light illuminated
    By Formy in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 31-05-2011, 04:49 PM
  4. Brake warning light Illuminated
    By a4suction in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-03-2011, 11:54 AM
  5. Emissions light illuminated on dashboard
    By meathead in forum Golf MK4 - 1999 - 2004
    Last Post: 19-07-2008, 03:39 PM
