Thread: Bend Lighting Intermittent fault
  1. Bend Lighting Intermittent fault
    Oct 2015
    Hertfordshire
    My Passat CC bend lighting function is intermittently having issues, mostly it’s fine but occasionally (generally on a bumpy road) it will throw up the error saying it’s not working. Turn the engine off and on and it works fine again.
    It’s not time based as I’ve done many long runs without an issue, it only seems to happen on bumpy roads so I am thinking it could be a loose connection or maybe a bulb on its way out?
    Before I start checking all the wiring I wanted to see if anyone else has had the same issue?
    Thanks in advance
    Ben
  2. Re: Bend Lighting Intermittent fault
    1840 Post(s)
    A waste of time checking the wiring, it is a digital CAN BUS system. What has happened should leave a fault code so first of all a full car scan with PROPER VAG capable equipment.
  3. Re: Bend Lighting Intermittent fault
    Oct 2015
    Hertfordshire
    Thanks for your advice, I will get the car scanned
  1. Please Help 9N polo lighting/indicator fault
    By andy198712 in forum Polo - Derby - Lupo - Fox
    Last Post: 26-07-2017, 07:08 AM
  2. Lighting Fault - Help Needed
    By gti_8v in forum Golf MK3 - 1993 - 1999
    Last Post: 13-09-2009, 11:07 AM
  3. Intermittent lighting fault
    By jetdave in forum Golf MK4 - 1999 - 2004
    Last Post: 29-03-2009, 06:23 PM
  4. HELP! Audi a6 Dynamic lighting fault
    By alcock555 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-03-2009, 08:18 PM
  5. Interior lighting fault
    By mikelds in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-12-2007, 11:34 PM
