Thread: Removing valve body / mechatronic unit from tiptronic transmission
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Removing valve body / mechatronic unit from tiptronic transmission
    1840 Post(s)
    Yes I had guessed your car spot on so that is what is shown, I will email the full docs.
  2. Re: Removing valve body / mechatronic unit from tiptronic transmission
    May 2008
    26 Post(s)
    Awesome, thanks Crasher. I received the info you sent and want to say a big thank you for helping out
    2007 A6 Allroad 3.2 FSI Tiptronic (C6 pre-facelift) - left hand drive
  3. Re: Removing valve body / mechatronic unit from tiptronic transmission
    May 2008
    26 Post(s)
    Quote Originally Posted by zit501 View Post
    I've cleared the clutch adaptions on VCDS a few times before. IIRC, in the transmission controller (channel 2), you go to adaptations - 10, go to channel 01, test, save.
    That should clear all the values in channels 73-77. The box might have to be above a certain temp to get it to clear, but it does work.
    Don't let anyone tell you that you can do it by holding down the pedal and switching on and off the ignition or some other story.
    Thanks. Like Crasher said, I am ok with clearing values, just a bit fuzzy on how to initiate the learn process to set the new adaptations. But I have also been advised by a transmission repair specialist in US that he would not normally clear the adaptations simply from an ATF + filter and mechatronics sleeves change, but only if he had also changed one or more solenoids.
    As crasher says, the box does adapt once in a while on its own (as long as the prerequisites listed in the audi SSP are met), but I guess the clincher will be to see how it is shifting after carrying out the work.
    Having read up on torque converter lockup clutch operation overnight, I’m becoming less optimistic that the steps I’m proposing to take will actually fix my problem, but will go through with it as it’s something to try. I don’t fancy diving straight into a TC replacement...
  4. Re: Removing valve body / mechatronic unit from tiptronic transmission
    Aug 2016
    Cape Town, South Africa
    Get SSP 385, it has the best adaption info I've found on the 09L. Read the entire adaption section, but specifically pages 69 to 73.
    2006 A6 Avant 3.0 TDi Quattro
  5. Re: Removing valve body / mechatronic unit from tiptronic transmission
    May 2008
    26 Post(s)
    Thanks. Already got it, and already read it twice. It takes a few times for that kind of detailed engineering info to sink into my noggin. I have a few ZF docs too. I find it all fascinating just how sophisticated these gearboxes are - and of course all this was being developed in early 2000s, goodness knows what they’re onto now, 20 years later. And then electric cars come along and spoil it all by making these transmissions obsolete...
  1. DSG Mechatronic Electronic Control Unit Scheme Issue
    By zihniates in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-09-2018, 01:32 PM
  2. Question Does DSG Mechatronic unit replacement mean the DSG oil is changed
    By MattPassat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-01-2015, 03:02 AM
  3. Searching for supplier for Mechatronic Unit
    By jononorman in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 18-09-2013, 11:14 PM
  4. Please Help mechatronic unit out of warrenty- advice needed
    By romnarz in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-07-2013, 11:05 PM
  5. Question DSG Mechatronic Unit
    By danieljames in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-10-2012, 09:11 AM
