Thread: 2011 Passat 2.0 TDI CFFB Engine - can you use VCDS to lock shut EGR valve
  1. Question 2011 Passat 2.0 TDI CFFB Engine - can you use VCDS to lock shut EGR valve
    Apr 2019
    Good Morning!
    As the EGR gas flow is a function of the ECU activity, can you force
    the system to keep the EGR valve closed, this with a view to diagnosing
    a defect in the EGR control system? I am loathed to start blanking off
    pipes to do this as I suspect the lumpyness an 1500-2000 is the valve (95k miles).
    If you can do this, what am I switching out/over/off/on (newbie but VCDS full licence)
    Dr B
    from: http://www.volkspage.net/technik/ssp/ssp/SSP_316.pdf
  2. Re: 2011 Passat 2.0 TDI CFFB Engine - can you use VCDS to lock shut EGR valve
    1840 Post(s)
    There are a number of EGR testing functions in VCDS but these can say one is OK when it isn’t.
  3. Question VCDS EGR test 2.0 TDI CR.....WAS: 2011 Passat 2.0 TDI CFFB Engine - can you use VCDS to lock shut EGR valve
    Apr 2019
    Hi Everyone!
    I ran the VCDS EGR test however I am not sure I recorded the right data during the test, do we have any clues as to what to measure and how a working EGR system would shape up? The test runs ok and prompts for brakes and foot on the accellerator, plug lamp flashes and rpm is governed. The key elements would be the two readings to compare, here I have used-
    EGR specified value ( %)
    EGR solenoid valve: actual value ( %)
    However this was not based on any real reasoning- this is what came out (note the scale on the right)
    For the record I recorded
    EGR specified value
    EGR Vacuum Regulator Solenoid Valve: activation
    Engine speed
    Engine torque
    Exhaust gas recirculation (EGR) cooler pump: specified value
    The CSV datafile is here:
    egr LOG-01-IDE00405_&5.CSV - Google Drive
    It has the timestamps for each reading of each variable, I resorted the data in Excel thus:
    egr LOG-01-IDE00021_&5.xlsx - Google Drive
    May repeat with TURBO to get more granularity
    NEXT? Looking to use VCDS to lock out the EGR valve to see if the judder is gone.... youtube helped here:
    VW A4: ALH TDi EGR Adaptation (to minimum operation value) - YouTube
    However locking it out long term is NOT an option as the EGR is used in the DPF regeneration
    cycle - so it won't so the DPF will block up [what I didn't think to do was to see if the DPF state
    could be monitored to MANUALLY regenerate it? Not sure that the warning light for the DPF
    would signal TOO LATE to regenerate..... another issue this ]
    Any thoughts most appreciated
    Dr B
  4. Re: VCDS EGR test 2.0 TDI CR.....WAS: 2011 Passat 2.0 TDI CFFB Engine - can you use VCDS to lock shut EGR valve
    1840 Post(s)
    There is a very simple answer to all this, 03L 131 512 DQ.
  5. Re: VCDS EGR test 2.0 TDI CR.....WAS: 2011 Passat 2.0 TDI CFFB Engine - can you use VCDS to lock shut EGR valve
    Apr 2019
    Simplest may not be the least expensive.....
    Will report back....
  1. Replies: 1
    Last Post: 09-06-2016, 01:33 PM
  2. Passat B5 estate 04 plate 1.8 petrol bonnet latch problem....won't shut/lock
    By 100949football in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-06-2015, 07:22 PM
  3. Please Help 2011 Passat TDI Longlife service reset with VCDS - Adaptation error
    By master220 in forum VCDS - Help Requests
    Last Post: 02-02-2015, 07:54 PM
  4. Replies: 3
    Last Post: 25-08-2013, 05:17 PM
  5. EGR Valve Shut off
    By VEEDUBYA in forum Archive posts
    Last Post: 02-05-2007, 09:21 PM
