Thread: 2.0 TDI Engine management fault - pump stuck??!?
  1. 2.0 TDI Engine management fault - pump stuck??!?
    May 2019
    Newton le Willows, UK
    Today, I got an engine management fault and plugged in the computer to the ODB port. IT came up with a error of "pump stuck". Thats it?! Any ideas what pump this could be? There are no error codes too....
  2. Re: 2.0 TDI Engine management fault - pump stuck??!?
    1836 Post(s)
    A common problem with generic codes readers, did it give a number?
  3. Re: 2.0 TDI Engine management fault - pump stuck??!?
    May 2019
    No number... I will have another go tomorrow.. I was told there is a common problem with water pumps on these engines, like they have a mechanical and electric pump?
  4. Re: 2.0 TDI Engine management fault - pump stuck??!?
    1836 Post(s)
    Some versions have an electrically controlled mechanical pump, an electric one for the intercooler and an electric one for the heater matrix. The intercooler pumps are a common problem, TPS depots tend to hold a few of each version.
  5. Re: 2.0 TDI Engine management fault - pump stuck??!?
    May 2019
    It turns out that its the Inter cooler Water Pump. The solenoid is stuck to they have to replace the whole pump?!? Do you know if this kind of job is expensive?
  6. Re: 2.0 TDI Engine management fault - pump stuck??!?
    1836 Post(s)
    Solenoid it is an electric induction pump, there are two different makes Bosch or Pierburg and you could have either so you have to take it off first.
  1. Please Help engine management system fault& esp fault warning lamps coming on at same time.
    By passahat in forum Golf MK5 - 2004 - 2009
    Last Post: 02-03-2014, 09:22 PM
  2. Help Needed - Engine Management Fault?
    By East Antrim G in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-06-2011, 10:15 AM
  3. engine management fault codes
    By audi-nutz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-03-2008, 07:13 PM
  4. Engine management Light - No fault????
    By koyot in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-12-2007, 09:57 PM
  5. A4 ESP/engine management fault
    By Smash18 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-08-2006, 12:12 AM
