Thread: High beam bulb replacement
  1. High beam bulb replacement
    May 2019
    How do you change high beam bulb on Mk5 golf
    Do you have to take out the air filter box first?
  2. Re: High beam bulb replacement
    1841 Post(s)
    The left is nearly impossible without, you would lose a lot of knuckle bark...
  3. Re: High beam bulb replacement
    May 2019
    I've looked on you tube and it looks like it would be easier to remove the whole headlight to replace the bulbs
  4. Re: High beam bulb replacement
    1841 Post(s)
    Yes but you have to remove the bumper.
  5. Re: High beam bulb replacement
    Jul 2019
    Some grown up people with medium sized hands can do it. I know a guy who sells bulbs and he changes them without a sweat, so I usually take the car to that guy, buy the bulb from him and he replaces it for free. The bulb is a bit more expensive than usual, but just a few pennies.
    I agree VW should have thought this through, its a real pain for a regular guy to change a plain bulb and that shouldn't be the case in the 21st century.
  1. Passat 2015 high beam bulb change
    By hudson0804 in forum Passat - B8 Forum - 2015 -
    Last Post: 23-09-2018, 02:38 PM
  2. B8 R Line headlight and high beam bulb recommendations?
    By MattB247 in forum Passat - B8 Forum - 2015 -
    Last Post: 07-08-2018, 06:47 PM
  3. Low beam bulb replacement
    By Jack Power in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 11-11-2009, 03:36 PM
