Thread: '06 Audi A3 2.0 Tdi 170 BMN P1269 Implausible Signal / P1266 Implausible Signal
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: '06 Audi A3 2.0 Tdi 170 BMN P1269 Implausible Signal / P1266 Implausible Signal
    Mar 2019
    Whereabouts is that valve block? I can only see the n75 and a couple of solenoids
  2. Re: '06 Audi A3 2.0 Tdi 170 BMN P1269 Implausible Signal / P1266 Implausible Signal
    1837 Post(s)
    According to ELSA the 2006 BMN has the valve block but ETKA says individual valves. You need to check the shared vacuum feed to all three valves and that the N75 provides a vacuum when the screen indicates it should do.
  3. Re: '06 Audi A3 2.0 Tdi 170 BMN P1269 Implausible Signal / P1266 Implausible Signal
    Mar 2019
    There’s a vacuum being supplied to the valves and N75 but the N75 isn’t providing a vacuum during the test. Also there’s 3.5v coming from the N75 connector with the engine on and when I run through the test it drops to 0.5v, does that sound about right?
  4. Re: '06 Audi A3 2.0 Tdi 170 BMN P1269 Implausible Signal / P1266 Implausible Signal
    1837 Post(s)
    You should have roughly battery voltage at the connector with the engine running, it is earth triggered.
  5. Re: '06 Audi A3 2.0 Tdi 170 BMN P1269 Implausible Signal / P1266 Implausible Signal
    Oct 2023
    Hungary
    Quote Originally Posted by mcmurray View Post
    Thanks for your reply, I'm beginning to regret getting something with a BMN in now - it seems to be running better now it's got a full tank of fuel so I'm not sure whether the in tank pump is dodgy or the fuel that was left in it was dodgy. You're right though, the dpf has been cut open so that partly explains the smell! The engine starts, idles well and revs freely now but there's absolutely nothing coming from the turbo, a new actuator has been fitted by the previous owner and it appears the wiring has been 'checked' (bits and pieces of the protective casing have been removed on all sorts of wires to presumably check for damage). The actuator arm moves freely by hand but what else can I check in terms of the actuator / turbo? I'm not getting any codes on VCDS now.
    Hello. did you manage to find the p1269 error code?
  1. Audi A4 2.0 TDI BPW Cab - G28 Engine Speed Sensor Implausible Signal
    By brasiliangringo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-11-2015, 11:19 PM
  2. Replies: 0
    Last Post: 16-01-2012, 09:16 PM
  3. Question mk4 golf 1.6 g62 implausible signal
    By sean gibson in forum Golf MK4 - 1999 - 2004
    Last Post: 04-12-2009, 10:55 AM
  4. Brake Switch (F): Implausible Signal
    By PoloMatch2001 in forum VCDS - Help Requests
    Last Post: 08-06-2009, 09:22 PM
  5. MAF Implausible Signal
    By idawson in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-10-2007, 02:25 PM
