Thread: Front wiper strange problem
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
  1. Front wiper strange problem
    Jul 2009
    poole
    So... one morning my front wipers stopped working. After driving for about 5-10 minutes they start working again intermittently. This happens every morning. I’m guessing it can’t be the motor or fuse as they wouldn’t work at all.
    any suggestions?
    thanks
  2. Re: Front wiper strange problem
    Near Blackpool
    48 Post(s)
    Bad earth or relay is my guess.
  3. Re: Front wiper strange problem
    Jul 2009
    poole
    Quote Originally Posted by jonathanfenton View Post
    cheers mate.
    ive read that the relay is beneath the steering wheel? Is this right and how easy is it to get to?
  4. Re: Front wiper strange problem
    Near Blackpool
    48 Post(s)
    Think it’s a couple of 7mm bolts that hold the panel in. Might just pull off but they are under there above the pedals. Either test with a meter or try flicking it when they don’t work and see if it then clicks. If it clicks each time you operate but the motor doesn’t always spin then could be the motor dying or a bad earth.
  5. Re: Front wiper strange problem
    Jul 2009
    poole
    Any idea which relay it is as i cant seem to work out which it is. Have wiggled them all but hasnt made a difference.
  6. Re: Front wiper strange problem
    1840 Post(s)
    There is no relay... 8P wipers are LIN BUS controlled from the central electrics unit which gets its instruction to run from the steering column electronics unit.
    The power comes from fuse 19 or 31 in the engine bay fuse box, which one depends on the cars specification.
    Do you have an aftermarket HID conversion fitted?
  7. Re: Front wiper strange problem
    Near Blackpool
    48 Post(s)
    Ha there you go, I stand corrected
  8. Re: Front wiper strange problem
    Jul 2009
    poole
    Thanks.
    No aftermarket HID
  9. Re: Front wiper strange problem
    Near Blackpool
    48 Post(s)
    I’d go with faulty motor then, changed mine twice now for 2nd hand units so guessing they are coming to the end of their working lives the 2006 ones
  10. Re: Front wiper strange problem
    1840 Post(s)
    Likely to be the motor, I have changed quite a lot of them but mostly on cabrio's for some odd reason. Which year is yours?
  1. Strange problem with front wipers
    By rick343 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 17-10-2015, 08:56 AM
  2. Strange problem with front wipers
    Last Post: 15-10-2015, 10:54 PM
  3. Question 05 1.2 Polo Front Wiper Problem-Please Help!
    By adoherty in forum Polo - Derby - Lupo - Fox
    Last Post: 03-02-2009, 07:51 PM
  4. Few issues... Power loss, strange wiper problem, hard to start!
    By Kris214 in forum Golf MK4 - 1999 - 2004
    Last Post: 09-04-2008, 09:56 PM
  5. Front Wiper Problem, Please Help!!!!
    By andysubaru30 in forum Audi A3 - Archive Topics
    Last Post: 11-02-2008, 09:48 PM
