Thread: Touran 2011 parking sensors
Results 1 to 8 of 8
  1. Touran 2011 parking sensors
    May 2019
    Hi Guys
    I am after some help, both front and rear parking sensors are not working on my touran. The button near the gearbox is illuminated but no sound
    can anyone advise of any troubleshooting steps I can take before I have to take into the garage, ie a fuse etc?
    Thanks in advance for you help
  2. Re: Touran 2011 parking sensors
    108 Post(s)
    1816 Post(s)
    If it is a factory fitted system it is linked into the diagnostic system so a code read would save a lot of time.
  3. Re: Touran 2011 parking sensors
    May 2019
    Hi Crasher
    thanks for the reply it is a factory fitted system,, will get the scan done and post the results
    on a side note does anyone have a fuse box diagram for the car?
    thanks
  4. Re: Touran 2011 parking sensors
    May 2019
    quick update guys car went in for a dsg oil change today the dealer contacted me with regards to some other repair work, dont they always !!!
    interestingly the parking sensors were not mentioned and they did not see anything on the onboard computer showing anything relating to it,,, any ideas on how to troubleshoot?
  5. Re: Touran 2011 parking sensors
    108 Post(s)
    1816 Post(s)
    Before shouting at them "use the ODIS properly you muppets" you need to establish if these sensors are factory fitted or aftermarket. To make this easier, PM me your reg and I can tell you.
  6. Re: Touran 2011 parking sensors
    108 Post(s)
    1816 Post(s)
    Yes it has Pr-7X5 full front and rear factory fitted Park Distance Control so tell them to pull their fingers out and do their job properly using their “ODIS” system under “Guided Fault Finding” and to do their job properly..... disgraceful...
  7. Re: Touran 2011 parking sensors
    May 2019
    The car is no longer at Vw will take it to a local garage and ask them to try fault finding using the onboard computer
  8. Re: Touran 2011 parking sensors
    May 2019
    quick update a faulty sensor was replacing and all is working fine,,, thanks for the help CRASHER
  1. Touran re enable parking sensors
    By Jon.hilly in forum Touran - Sharan - Caravelle
    Last Post: 05-02-2017, 11:51 AM
  2. Replies: 0
    Last Post: 07-07-2015, 04:31 AM
  3. Replies: 1
    Last Post: 14-11-2014, 11:22 AM
  4. 2011 touran fitting parking sensors
    By steve! in forum Touran - Sharan - Caravelle
    Last Post: 21-09-2012, 02:13 PM
  5. Touran aftermarket parking sensors bumper removal
    By robbolevens in forum Touran - Sharan - Caravelle
    Last Post: 11-07-2012, 05:43 PM
