Thread: DPF issue
Results 1 to 10 of 19
  1. DPF issue
    Dec 2014
    Brewtopia
    Evening all,
    I'm hoping someone can shed some light on this...
    The car is an A7 - 242ps (180kw) 7 speed quattro. The DPF light came on towards the end (thankfully) of an 800 odd mile round trip. The light was on for around a minute, then went out, the heater plug light came on and the car went into limp mode. Fortunately, I was only around 10 miles from home, so I decided to carry on.
    I've had the car scanned with VCDS and it's coming up with the following..
    4 Faults Found:
    5188 - Diesel Particle Filter
    P2463 00 [237] - Excessive Soot Accumulation
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 2
    Engine speed: 2259.00 /min
    Normed load value: 99.6 %
    Vehicle speed: 69 km/h
    Coolant temperature: 90 °C
    Intake air temperature: 34 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 14.120 V
    Unlearning counter according OBD: 40
    P Flt Ld fac Ash Cor: 0.9310
    Particul.filter diff.pressure: 140 hPa
    Exh t Adap T Oxi Cat Ds: 285.8 °C
    Exh t Adap TP Flt Ds: 273.5 °C
    Exhaust gas jet volume in particle filter: 300.5 m³/h
    Current operating mode_2-Bits 0-7: 0
    Current operating mode_2-Bits 0-7: 1
    18660 - Start interruption due to insufficient engine speed
    P151D 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    5118 - Oxygen (Lambda) Sensor B1 S1
    P2195 00 [101] - Signal too Low (Lean)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Engine speed: 1302.00 /min
    Vehicle speed: 68 km/h
    Coolant temperature: 89 °C
    Intake air temperature: 20 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 14.160 V
    Air mass: actual value (mg/stroke): 232.5 mg/stroke
    Mean injection quantity: 15.45 mg/stroke
    Oxygen sensor 1 Bank 1: Status Calibration O2-Signal-Bits 0-7: 1
    O2 sensor 1: bank 1: voltage raw value O2 signal: 683.2 mV
    O2 sensor 1 bank 1: voltage reading Ri-signal: filtered.: 1000.2 mV
    O2 sensor 1 bank 1: duty cycle O2 heater: 42.92 %
    LSU r O2 Adap 0: 0.12154
    5189 - Particulate Trap Bank 1
    P2002 00 [109] - Efficiency Below Threshold
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Ambient temperature: 13.3 °C
    Particle filter: offset for differential press.: 0 hPa
    Particle filter: soot mass measured: 37.31 g
    Particle filter: soot mass calculated: 28.19 g
    Particle filter: kilometers since last regeneration: 778877 m
    Particle filter field regeneration: cancel conditions-Bits 0-7: 0
    Readiness: 1 1 0 0 0
    Looking at the soot values, I wouldn't have thought that they were that high (assuming they are correct)? I'm inclined to think that a sensor has gone down, possibly the pressure sensor.
    Any advice gratefully received..
  2. Re: DPF issue
    1835 Post(s)
    What version of VCDS was used, it seems to be missing some data like the time stamp? They all (apart from the engine speed) seem to have occurred at the same time and yes I would fit a gem (genuine only) pressure sensor and calibrate, then see if a forced regeneration when driving can be initiated.
  3. Re: DPF issue
    Dec 2014
    Brewtopia
    Thanks for the reply Crasher.
    DPF & particulate trap were at the same time. Lambda 5:02 later.
    Is there somewhere I can find min/max limits for the pressure sensor?
  4. Re: DPF issue
    1835 Post(s)
    It should be in the VCDS labels but they are rather incomplete. When I get an issue like this I change over to using ODIS for the Guided Fault Finding function direct back to VAG live ont interweb but very few non main dealers have this facility.... it dug me out of what would have been a hole today just coding in a new key chip to the dash on a Golf 5, what was previously a total sketch took a few minutes.
  5. Re: DPF issue
    Dec 2014
    Brewtopia
    I guess that level of tech is quite a financial commitment, so it's unsurprising that few have it.
    It's guite galling really. I've been driving Audi lease cars for over 10 years, covering around 350,000 miles and I've only ever had one car let me down, which was a 2007 A3, with a duff injector.
    I buy my own and get problems... All things considered, I'm still mega impressed with the A7.
    Just read your footer on your profile. Not a fan of diesels then..?
    Thanks for your replies, much appreciated.
  6. Re: DPF issue
    1835 Post(s)
    Diesel is fine where it belongs, in trucks, earth movers and boats...
  7. Re: DPF issue
    Dec 2014
    Brewtopia
    Well, the A7 looks like a boat from behind and moves the earth for me, so that's two out of three
    Normally, I'd say that four strokes is two too many anyway, but I'll leave that for today..
  8. Re: DPF issue
    1835 Post(s)
    I have equal contempt for engines that don't have four stokes, the noise and smell drives me mad, I rent one of my units across the car park to a bike mechanic and when he is bedding in new rings I have evil thoughts of murder...
  9. Re: DPF issue
    Dec 2014
    Brewtopia
    Erm.. Right, okay... I'll just keep my head down for a bit then..
  10. Re: DPF issue
    Jan 2013
    Wessex. and Southern France
    108 Post(s)
    It's okay, friend Crasher has no soul. How can anyone not be seduced by the sound of a Motocross bike tapped out!
  1. a6 oil sensor issue and airbag issue
    By 2400 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-12-2012, 11:26 AM
  2. Brake servo issue and possible linked boost issue
    By slipperyox in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2012, 10:06 PM
  3. Car issue
    By mark_davies in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-01-2012, 01:24 PM
  4. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
  5. '98 cab air con issue
    By sandscharles in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 08-08-2009, 10:36 PM
