Thread: Dynamic Steering error flashing on Dash?
  1. Dynamic Steering error flashing on Dash?
    Sep 2013
    leatherhead, UK
    HI,
    Got this on the car. Steering wheel offsets by 1/4 turn.
    Very helpful garage did the following:
    1. Full realignment set up conducted;
    2. Reset basic settings (seems to be the common approach to a fix);
    3. Fault reappeared as soon as i reversed into the drive (6 miles);
    4. Car returned to the garage;
    5. fault codes - 3110 and 00778
    6. Garage followed 'book' process to reset the Basic settings;
    7. Codes reset;
    8. took it for a drive - no problems;
    9. Parked up and restarted - fault reappears! - Frustrated;
    10. Garage now scratching head - as was I.
    11. Next option is to perhaps replace Steering angle sensor and reset.
    12. Currently driving the car until the fault reappears.................... before i bite the bullet.
    Any good ideas or similar experiences that can be shared?
    Audi A4 Avant B8 3.0TDI (240)
    Caterham 7 K series 1.8 150 ps
  2. Re: Dynamic Steering error flashing on Dash?
    1841 Post(s)
    Is the wheel straight when driving now?
  3. Re: Dynamic Steering error flashing on Dash?
    Sep 2013
    leatherhead, UK
    Crasher -
    The wheel reset after cycling the ignition and is within the 1.5 degree tolerance following basic reset, but it has been before.
    I remain concerned that the problem has not been fixed, do you know of any way that I can confirm a fix is truly in place?
  4. Re: Dynamic Steering error flashing on Dash?
    1841 Post(s)
    Is it visually offset one way or the other when driving in a straight line?
  5. Re: Dynamic Steering error flashing on Dash?
    Sep 2013
    leatherhead, UK
    TBH it is now as straight as it was before it went in for wheel realignment. i.e before the problem manifested itself.
  6. Re: Dynamic Steering error flashing on Dash?
    1841 Post(s)
    In that instance, performing the basic settings with the angle showing as near as possible 0 should solve it.
  1. Please Help P2563 error code, flashing coil light, flashing EML (engine) light
    By MHDxMK5BK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-07-2022, 09:41 PM
  2. Glowing plug flashing, error code. What you think?
    By Caxap in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-01-2014, 11:58 PM
  3. Allroad Dynamic Steering option - worth it?
    By Flattersplatter in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-10-2013, 11:10 PM
  4. 'c Error' On Dash Of Mk3 Gti Bv?
    By dipakpur in forum Golf MK3 - 1993 - 1999
    Last Post: 20-01-2009, 10:22 PM
  5. Dynamic Steering+Dampering thingie..
    By alexcf in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-08-2008, 11:14 AM
