Thread: 2.0 fsi drive shaft bearing
  1. 2.0 fsi drive shaft bearing
    May 2019
    Southend on sea
    Anyone know how to change a drive shaft bearing on drivers side have you got to take gearbox off or is there a easier way thanks
  2. Re: 2.0 fsi drive shaft bearing
    1840 Post(s)
    Do you mean the two piece offside driveshaft mid support bearing fitted to a few Golf 5’s and A3’s?
  3. Re: 2.0 fsi drive shaft bearing
    May 2019
    Southend on sea
    I think it’s in the gearbox side where it meets
  4. Re: 2.0 fsi drive shaft bearing
    1840 Post(s)
    They are the cv joint flanges, behind these are the differential taper roller bearings and to change these the box has to be completely stripped down and the diff removed. Then you fit two new diff bearing outer races with a spacer first in one side and a shim (say 0.3mm) in the other side, fit new inner races to the diff, re-fit only the diff and bolt the case halves back together. Then you use a dial gauge to measure how much float there is between the races and use this measurement together with a pre load figure and the thickness of the shim to calculate the thickness of the shim you need to install so that the new diff bearings are clamped together correctly. Yes, it is a lot of work, 99.9% of gearbox rebuilders don’t bother and just re-use the original thickness pre load shim and most of the time they get away with it. The advantage of this is too lose is better than too tight...........
  1. Drive shaft central bearing replacement
    By Guray in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 22-02-2018, 02:47 PM
  2. Alhambra intermediate drive shaft bearing
    By Davey p in forum Alhambra
    Last Post: 25-07-2015, 06:34 AM
  3. Please Help Prop Shaft Centre Bearing
    By chriswright1970 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-04-2010, 08:45 AM
  4. Drive shaft comes off
    By kaborex in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-12-2008, 12:09 PM
  5. drive shaft
    By r34 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-10-2008, 01:07 PM
