Thread: Non invasive inspection via endoscope/borescope of EGR valve (effect of BG245 treatment)
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. Re: Non invasive inspection via endoscope/borescope of EGR valve (effect of BG245 treatment)
    #21
    Apr 2019
    Quote Originally Posted by drjohnbullas View Post
    ......Does anyone publish a workshop manual that doesn't read like
    all the functioning parts were scraped into a skip and delivered
    to the authors before the guide was written?
    I'm ploughing through this directory courtesy of Google:
    google all this phrase: 2.0 tdi filetype: pdf site:volkspage.net/technik
    (remove the space before pdf.... it was being read as an emoticon!)
    Dr B
  2. Re: Non invasive inspection via endoscope/borescope of EGR valve (effect of BG245 treatment)
    #22
    1840 Post(s)
    Quote Originally Posted by Gazwould View Post
    That's odd they usually run better .
    Apparently so but there was little info on it back then and I found out it was against construction and use regulations plus I was becoming much more aware of the damage NOX emissions do, I was and still am learning.
    Dr John, the pipe from the head with the clamp brings the gasses from the cooler through the head (extra cooling effect) and sends them into the inlet manifold. The motor in front is called the V157 manifold flap on cars factory built without a variable port inlet manifold, it is a bit of a convoluted subject. For the correct workshop information visit https://erwin.volkswagen.de/erwin/sh...7C088.ASTPVWE1
  3. Re: Non invasive inspection via endoscope/borescope of EGR valve (effect of BG245 treatment)
    #23
    Apr 2019
    So could a EGR blanking plate be fitted here? Assuming I had sold my soul to the devil.
  4. Re: Non invasive inspection via endoscope/borescope of EGR valve (effect of BG245 treatment)
    #24
    Apr 2019
    UPDATE
    I just noticed the the "gaskets" shown in the first exploded diagram has tabs on the sides of it, does this mean that if you replace these gaskets you have to use one of the embossed metal items rather than the more traditional flat cut out gaskets i.e. you need to use one of these stamped metal devices
    Rather than one of these more traditional cut flat devices:
    I can see that the end of the pipe has a clamping surface with a groove in it.
  5. Re: Non invasive inspection via endoscope/borescope of EGR valve (effect of BG245 treatment)
    #25
    1840 Post(s)
    The tabs stop the gasket dropping off during assembly.
  1. Wonder how this will effect the MPG
    By Tripletrouble in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 29-08-2014, 01:56 PM
  2. Would fan switch effect air con
    By rocky76 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-05-2011, 12:16 PM
  3. Question Buying a car: AA Inspection or VW Inspection
    By shooter999 in forum Golf MK5 - 2004 - 2009
    Last Post: 28-03-2011, 01:30 PM
  4. Wynns Hydraulic Valve Lifter treatment
    By trueplayz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-04-2010, 09:45 PM
  5. Question MY2010 LSD Effect
    By Hillbeley in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-07-2009, 11:53 AM
