Thread: Mk6 golf gtd Boost Pressure Sensor
  1. Mk6 golf gtd Boost Pressure Sensor
    May 2019
    Birmingham
    Hi all.
    Done a vcds scan of my car and its showing a Boost Pressure Sensor issue scan results below.
    1 Fault Found:
    005522 - Altitude Sensor / Boost Pressure Sensor
    P1592 - 000 - Implausible Correlation - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 31
    Reset counter: 255
    Mileage: 134032 km
    Time Indication: 0
    Date: 2013.10.05
    Time: 13:12:20
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Voltage: 12.01 V
    Absolute Pres.: 999.6 mbar
    Absolute Pres.: 1162.8 mbar
    Temperature: 11.7°C
    (no units): 1.0
    So I went to europarts and purchased a map sensor, (thrust sensor) vag call it? gave the guy my vin number and this is what he gave me.
    I thought this was a dpf sensor not map sensor.
    Forgive me for my lack of knowledge as I am just starting out on doing my own repairs. If this is correct have any of you kind people have any information on fitment.
    Chele.
    Edit. just seen thread relating dpf sensor is boost pressure sensor.
    Is this the right part to correspond to fault?
  2. Re: Mk6 golf gtd Boost Pressure Sensor
    1840 Post(s)
    Yes that is the DPF sensor, not the thrust sensor. ECP is staffed by Muppet's.
  3. Re: Mk6 golf gtd Boost Pressure Sensor
    May 2019
    Birmingham
    Thanks Crasher. Back to ECP to get correct one. Should of bloody questioned him when there.
    should look like this>>>
    Part number to correspond to vim.
    Would boost sensor be the issue to vcds scan?
    Chele
  4. Re: Mk6 golf gtd Boost Pressure Sensor
    1840 Post(s)
    Depends on the engine year and type code.
  1. Help boost pressure sensor
    By Clarkey9592 in forum 2.0TDi - Engine
    Last Post: 09-08-2018, 08:11 AM
  2. Turbo Boost Pressure Sensor
    By Maximightus in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-01-2016, 05:37 PM
  3. Please Help 1.9 tdi 90 boost pressure sensor
    By chris_90 in forum Vento - 1994 - 1998
    Last Post: 20-04-2014, 10:53 PM
  4. DPF / Boost Pressure Sensor issues...
    By A1Dan75 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-01-2012, 11:13 AM
  5. Boost pressure Sensor
    By Frankiebaby in forum Golf MK5 - 2004 - 2009
    Last Post: 10-09-2009, 12:11 AM
