Thread: Brake warning light and MOT
Results 1 to 10 of 11
  1. Brake warning light and MOT
    Shortly after last years MOT my brake warning light came on, the amber circle with three dashes either side. This normally indicates worn pads, but the pads are fine, so is the brake fluid. IT just randomly came on and comes on every time the ignition is turned on.
    Trouble is, my MOT is out and my tax goes out on the 1st of June, simple question really, will the warning light automatically fail the MOT even if they test the brakes and find them to be in good working order.
    Thanks.
    audi a4 1.9tdi Avant PD engine. 2000
  2. Re: Brake warning light and MOT
    Just took one wheel off and saw the sensor cable going to one of the brakes wrapped in tape, undoing this I saw two wires tied together; not sure if this has anything to do with it since it must have been like it when I got the car.
  3. Re: Brake warning light and MOT
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    I think yes, I had an issue with my 2002 A4 cabby which showed the symbol for worn pads when they were not.
    A simple google search showed which wires in the loom to join, in order to totally and permanently bypass the pad ware indication.
    Some have had luck joining the wires to the pad indicator but this can be short lived, so best to go directly into loom, mine was a simple earthing of one wire and moving another if I remember correctly, and the area was located behind the nearside kick panel.
    I am not an expert or guru but this worked for me and clearly fine at my mot test, you are only disabling pad ware indicator and no other safety device.
    1 1 0
  4. Re: Brake warning light and MOT
    Oct 2009
    10 Post(s)
    Ah, you were typing at the same time I was posting.
    That bodge repair is exactly your problem, you may be successful refreshing the repair but if not , check out the above solution.
    Also bare in mind the location of said loom may be different on the b5 from the b6.
    I think there was also a place in the back of you dash binnacle where you can make the bypass, good luck
    1 1 0
  5. Re: Brake warning light and MOT
    Right ok, worth ago, because I cannot see any sensor coming off the brake pads themselves. It looks like, for what ever reason, some one in the past has cut the wear wires to the brake pads.
    I do see that a replacement cable on ebay is quite cheap, but I guess I'd have to get new pads as well
  6. Re: Brake warning light and MOT
    This looks quite technical and electric for me, but I got no option; I'll need that luck.
  7. Re: Brake warning light and MOT
    It looks very much like somebody has done this but now it no longer works:
    How to Turn OFF Brake Pad Warning Light on ANY Car - YouTube
    Question is, why on earth would anybody do this?
  8. Re: Brake warning light and MOT
    Oct 2009
    10 Post(s)
    I think people do this if they decide to buy after market and sometimes up rated pads that dont have the sensor facility.
    The problem is that when done poorly, as your photo, the issue will return.
    Also you could sometimes chase the plug/wiring all through the inner wing looking for a scuff or break in the wires, and never find a fault.
    This is where a loom bypass is actually removing the indication facility permanently.
  9. Re: Brake warning light and MOT
    I'm already out of MOT and tax goes out in 10 days, so I'll have to look into this loom solution, but it seems a bit complex, hopefully it's one of those things that reads harder than it looks.
  10. Re: Brake warning light and MOT
    Dec 2014
    Bedford
    42 Post(s)
    No will not fail the mot on this issue, was a fail this time last year but now is classed as a minor advisory.
    Sent from my SM-G970F using Tapatalk
    1 1 0
  1. Red brake warning light flashing and constant abs light
    By lee.p.wood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-08-2014, 06:45 PM
  2. Replaced Brake fluid (bled system). Red Brake warning light appears!
    By keemaklan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-12-2010, 03:21 PM
  3. Flashing colant light and no brake warning light
    By cookie7354 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-09-2008, 11:24 PM
  4. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
  5. Brake fluid warning light with ABS light
    Last Post: 02-04-2007, 03:28 PM
