Thread: A7 3.0TDI Engine Rattle
Results 11 to 20 of 39
  1. Re: A7 3.0TDI Engine Rattle
    108 Post(s)
    1816 Post(s)
    And they have the nerve to call this a full Audi service history.... 30k without an oil change!
    Inspection with Oil change (flexible) 2018-12-20 133630 mi
    Additional work 2018-07-11 118773 mi (brake fluid, Ad Blue, cabin filter)
    Service record Inspection with Oil change (flexible) 2018-07-09 118773 mi
    Service record Inspection with Oil change (flexible) 2018-01-06 99410 mi
    Service record Inspection with Oil change (flexible) 2017-04-21 73761 mi
    Service record Inspection with Oil change (flexible) 2016-06-17 43984 mi
    Service record Inspection with Oil change (flexible) 2015-11-20 24850 mi
    Interestingly it is EU6+ so ULEV OK.
  2. Re: A7 3.0TDI Engine Rattle
    Huddersfield, UK
    Crasher, could you please help me with the engine number / code and what BHP this car is? Am I right to assume it is 245BHP? Thank you.
  3. Re: A7 3.0TDI Engine Rattle
    108 Post(s)
    1816 Post(s)
    No, it is the 218BHP/160Kw CRTE..... why?
  4. Re: A7 3.0TDI Engine Rattle
    Huddersfield, UK
    Looking for more grounds to put a fight up for returning and receiving a full refund. I did read 160Kw on the service handbook but still thought it was 245BHP. I had a 13 Reg A6 3.0 TDI Quattro before this purchase and the engine was so quiet. Nothing like this one. I'm so gutted.
  5. Re: A7 3.0TDI Engine Rattle
    108 Post(s)
    1816 Post(s)
    I am surprised Audi did not void the warranty at the first service never mind the second. This all backs up what I have said for decades, FSH means ********!
  6. Re: A7 3.0TDI Engine Rattle
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    If I was you I'd return for a full refund and treat it as a lesson learned. Looking at that service history first service was 5k late, another was 10k late and others nearly 5k late. Last owner/user has killed that car. I drive the 218bhp in an Allroad and the engine is as quiet as my last C7.
    Has the gearbox been serviced correctly, my guess is probably not as the rest of the car hasn't been.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  7. Re: A7 3.0TDI Engine Rattle
    #17
    108 Post(s)
    1816 Post(s)
    We are just doing the head on a 2010 Ibiza Bochanegra with worn valves guides and low compression. As a precaution we are doing a full chain set including the oil pump itself. At low mileage (can't see at the moment, battery off) the timing chain and gears are completely worn out and the oil pump chain tensioner disintegrated in my lads fingers. This is down to three factors, removing the metal additives (such as ZDDP) from the oil and the use of Hy-Vo® chains instead of the old roller versions. Add to that systematic huge abuse of oil changes intervals and what you get are destroyed engines that would have lasted three times as long if looked after and run on proper oil.
  8. Re: A7 3.0TDI Engine Rattle
    #18
    Near Blackpool
    48 Post(s)
    Not much your joe blog guy can do apart from use the oils that match VAG spec and follow their service schedule, I thought they monitored the oil quality and advised you when it’s degraded enough to warrant changing?
    I suppose changing oil and filter more often is all we can do?
  9. Re: A7 3.0TDI Engine Rattle
    #19
    108 Post(s)
    1816 Post(s)
    Where there are any wiping surfaces, we need different oil. What is needed is an additive which will protect wiping surfaces such as flat tappet cams and non roller chains but not damage the cat/lambda sensor if the engine burns oil. Liqui Molly were supposed to be working on something.
    https://pim.liqui-moly.de/pidoc/P000...ec-34.0-en.pdf
  10. Re: A7 3.0TDI Engine Rattle
    #20
    Near Blackpool
    48 Post(s)
    Still not entirely sure why they would split inspection with oil change. Surely the two go hand in hand?
  1. Cold start rattle 2.0TDi, gone at 1100RPM or warm engine - Any ideas
    By maverix in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-02-2017, 02:21 PM
  2. No! Rattle from 3.0tdi V6
    By h20ruf in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 25-01-2014, 08:18 AM
  3. 05' A6 2.0tdi Engine Rattle
    By Lewis.A6 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-01-2012, 10:42 AM
  4. Please Help A3 2.0TDI Clutch Judder, rattle,
    By harm81 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 31-05-2011, 01:19 PM
  5. Please Help B7 - A4 2.0TDi S-Line Cabriolet Dashboard Rattle
    By Lookything in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-10-2008, 11:40 PM
