Thread: 2003 allroad 2.5 tdi central locking not working from key fob.
  1. 2003 allroad 2.5 tdi central locking not working from key fob.
    Gravesend, Kent
    Apologies if this has been covered elsewhere, and if it has, can someone point me towards it.
    Anyway,
    a few months ago, I started to experience flat battery problems. I immediately dismissed the battery as it was new in October last year. After changing the alternator and still experiencing the problem, I took the battery back and lo and behold it was the battery at fault. It was only putting out 100 of the stated 800 Amps. Until this point, the central locking was working correctly from the key fob on both the main and the spare keys. The car locks all doors if I use the key in the lock and also auto closes when in motion.
    However, once I changed the battery in the car, the central locking has refused to work from the key fob.
    I have tried several methods found on the interweb but to no avail. I have also tried using vcds but again, I can't seem to sync the keys to the car. Is it something I'm doing wrong or is it something I'm not doing at all.
    Regards,
    Graham.
    Fire Up The quattro!!!!
  2. Re: 2003 allroad 2.5 tdi central locking not working from key fob.
    106 Post(s)
    1813 Post(s)
    I get this with the 4B every time we change a battery, you just have to keep doing the adaption process but I find you need two keys to get it to work. Sometimes just holding the button down with the ignition on will work but I find that is only very successful on the $4 cabrio and don't ask me why because I don't know! I like the user name.
  3. Re: 2003 allroad 2.5 tdi central locking not working from key fob.
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    Scan for fault codes and delete them
  1. 2003 passat central locking
    By jackamp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-02-2010, 09:08 AM
  2. Central Locking Bora 2003 1.9 TDI
    By CHE2005 in forum Bora - 1998 - 2005
    Last Post: 26-07-2008, 07:25 PM
  3. Allroad Central Locking
    By Giraffe in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-04-2008, 02:31 PM
  4. SOS! Remote Central Locking not quite right on a 2003 C5 1.9 TDI
    By paul b in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-04-2008, 08:17 AM
  5. Replies: 1
    Last Post: 14-10-2007, 12:06 PM
