Thread: 2.7 TDI Injector Fuel return L shaped nipple
  1. 2.7 TDI Injector Fuel return L shaped nipple
    May 2015
    Birmingham
    6 Post(s)
    I was replacing the injector seals on my 2.7 Tdi A6, however while doing so on two of the injectors I accidently took off the L shaped fuel return nipple. Now I can clip them back on to the injector however when running the engine they leak fuel. Are the injectors ruined now or is there a special way to clip them back on??
  2. Re: 2.7 TDI Injector Fuel return L shaped nipple
    1837 Post(s)
    A new O ring should seal it, WHT 007 480 A but £9.50 each..... If the return line is damaged that is only available as a complete assembly 059 130 218 H at £294.23.... plus the O rings.
  3. Re: 2.7 TDI Injector Fuel return L shaped nipple
    May 2015
    Birmingham
    6 Post(s)
    Hi Crasher,
    Thanks for the info.
    Ive been messing about with it since the post, its definately leaking from the nipple on the injector. I have injectors 059 130 277 S. Seems like the leak is because L shaped fuel return isnt really clicking back onto the injector. Il buy some O rings and give that a try.
  4. Re: 2.7 TDI Injector Fuel return L shaped nipple
    May 2015
    Birmingham
    6 Post(s)
    Okay so time for a follow up, I hope this helps anyone in the future.
    I have the earlier injectors so the fuel leak off port is detatchable from the injector head, newer injectors are made from one piece.injector 2.jpg
    I had diesel leaking from the leak off port thats part of the injector and the fuel return line.
    The fuel return line was a very simple and easy fix, a new O ring as crasher suggested and that stopped the leak from there.
    However the fuel was still leaking out from the L shaped leak off port on the injector head, looking closely I noticed although the port clipped on, once the engine was started it would come loose. I guessed the o ring inside this port was pushing against it under pressure and causing it to come off. So I decided to wrap a heat resistant cable tie around it and it stopped the leak.
  1. Question Fuel return pump
    By Necroscope in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 08-09-2015, 05:13 PM
  2. A6 2005 3.0 tdi fuel return lines
    By tillycom in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-04-2013, 10:32 AM
  3. A6 Avant 1.9 tdi fuel return
    By Jimmy B in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-06-2010, 08:02 PM
  4. V6 TDI -Injector return leak making a mess
    By Veeman in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-08-2008, 04:13 PM
  5. Fuel feed and return
    By hollowrp in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-03-2008, 12:00 PM
