Thread: Ccm control module wiring
  1. Ccm control module wiring
    Dec 2018
    Aberdare South Wales Cf44
    Has anybody got a working diagram for the ccm unit especially the two plugs. I have a Passat b5.5 3b3 1.9tdi saloon 2002. I can't seem to find a conclusive diagram. At present i put a used ccm box in because the original was flooded. I now have interior lights, windows etc.. i have an on going problem with the windows. Sometimes they won't go down and sometimes the rear door won't close. I have connected once wire from the loom to four others of the same colour and they work. I haven't soldered them and occasionally i have to pinch the bone connection then all is good. Vcds showed multiple errors regarding can bus, door modules etc etc but i think they are all related to the ccm
    Any help appreciated
    Terry
    Sent from my SM-G960F using Tapatalk
  2. Re: Ccm control module wiring
    Dec 2018
    Still hoping someone out there has a wiring diagram from the ccm module to the passenger looms. I especially need to get the can bus function working. This is throwing numerous errors up. I know the car does not have can bus per se but there is some form of simplified can bus wiring. I think i have fixed the leak into the cabin but i can't put the ccm module and holder back into place until the wiring is fixed.
    Terry
    Ps i am thinking of purchasing some loom wire and just replacing sections at a time. Would .5mm cable be correct for the ccm and main loom wiring or 1mm?
  3. Re: Ccm control module wiring
    Jul 2019
    Combe Martin
    Hi might be able to help but will need more information. Alternatively, if you google Autodata and pay the first month's fee that will give you all the information you require for about a tenna!
    Hope this helps
  4. Re: Ccm control module wiring
    1837 Post(s)
    I can do this on Monday for you if you private message me your email and REG or VIN. Have you made sure the red/black multi welded connection is not corroded?
    This is a 4B AllRoad so the wires are different colours but the problem is the same
  1. Convenience module wiring/plugs
    By Golf tdi Hal in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-12-2012, 05:01 PM
  2. Replies: 5
    Last Post: 15-10-2012, 10:20 PM
  3. Question steering control module for cruise control
    By doggydoctor in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-07-2012, 11:02 AM
  4. Replies: 0
    Last Post: 09-07-2009, 03:03 PM
  5. Need help wiring my autowindow bright module
    By rudeboymcc in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-09-2007, 05:18 PM
