Thread: MMI Unavailable
  1. MMI Unavailable
    May 2019
    Winchester, UK
    I turned on my A4 2018 TFSI this morning and the screen was blank and on the driver display, the radio, media, navigation all had an error message stating they were currently unavailable. I tried using the volume button to run it in with no luck and restarting the car to no avail. Has anyone else had this issue and know how to resolve it.
  2. Re: MMI Unavailable
    May 2014
    Darlington
    78 Post(s)
    One of the modules has died in the MMI system, no other fix other than taking it to a dealer.
  3. Re: MMI Unavailable
    Feb 2017
    pinner , u.k.
    Quote Originally Posted by huwc View Post
    u need to loop bypass each module, buy cheap on ebay, then test 1 module at a time until u find problem one
  4. Re: MMI Unavailable
    Feb 2017
    pinner , u.k.
    look at this thread, happend to me and i found in my case to be the bluetooth module faulty.
    MMI starts and then turns off
    Question MMI starts and then turns off
  5. Re: MMI Unavailable
    May 2019
    Winchester, UK
    Thanks for all suggestions, for some reason everything was working the next morning and has been since. I did see a possible issue with the MMI being unavailable due to low battery voltage so it may of been this.
  6. Re: MMI Unavailable
    May 2014
    Darlington
    78 Post(s)
    The car is under warranty, so just just tell your dealer when you book the car in for a service. A low battery won't stop the MMI switching on, however when it starts up a message will appear shortly afterwards regarding a low battery and shutdown the MMI system.
    Also there is no separate Bluetooth module on the B9 platform, it's built into the the main 3GP control module.
  1. Acc & Break guard unavailable
    By audi_norway in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 08-07-2020, 09:03 AM
  2. AAC unavailable
    By outofgas in forum Passat - B8 Forum - 2015 -
    Last Post: 22-09-2017, 08:32 PM
  3. Audi Connect - Service Currently Unavailable
    By royleblue in forum In Car Entertainment
    Last Post: 07-09-2017, 08:29 PM
  4. Coding II - 11 unavailable/greyed out
    By gdallas in forum VCDS - General Questions
    Last Post: 20-08-2013, 06:07 PM
  5. Manual unavailable ?
    By simon w-t in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-03-2011, 03:54 PM
