Thread: airbag ecu
  1. airbag ecu
    Mar 2011
    london
    hi all been lurking on here for a while i have recently purchased a a3 1.4 turbo sportback and have changed the front seat belts steering airbag and passenger airbag do I need to change the airbag ECU or can it be coded thanks oh its a 2010 cax engine 6 speed cheers
  2. Re: airbag ecu
    Mar 2011
    london
    any one ?
  3. Re: airbag ecu
    Mar 2011
    london
    all sorted apparently you can turn of the airbag light after a crash up to 4 times then you need to change the airbag ecu
  1. Replies: 0
    Last Post: 15-01-2018, 10:49 PM
  2. Airbag light on.....airbag sensor location G180?
    By bk.bas99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-12-2016, 04:56 PM
  3. Replies: 1
    Last Post: 17-06-2014, 02:54 PM
  4. Airbag Fault after trying to switch back on Passenger Airbag
    By platty25 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-08-2011, 10:47 AM
  5. Seats - Airbag sensor (Subframe with Airbag Resistor)
    By greg_gorr in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-08-2008, 08:43 AM
