Thread: Rear Foglight Problems
  1. Rear Foglight Problems
    May 2019
    I have a 2002 Beetle petrol engine. The rear foglight has stopped working and the tell-tail light on the instrument cluster also stopped working.
    I removed the switch. I put a 12v supply to the pin labeled NSL and the foglight came on and so did the tell-tail, there I assume bulb is fine and so is the instrument cluster light. I assumed it was the switch. I have bought two second hand ones and the problem remains the same each time.
    Any help much appreciated.
  2. Re: Rear Foglight Problems
    Nov 2006
    Crewe, Cheshire
    17 Post(s)
    Looks like you have no 12v coming into the switch from the fuse.
    Check in the owners manual which fuse & swop it.
    Worst case is that you will have to replace the wire between the switch & fuse if the fuse is ok.
  3. Re: Rear Foglight Problems
    May 2019
    Many thanks. I found this so will check fuse 36 today and report back.
  4. Re: Rear Foglight Problems
    May 2019
    Just checked fuse 36 and thats OK
  1. will a foglight from an A4 fit an A6
    By vwnige in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-09-2011, 01:22 PM
  2. Question RS4 foglight bulbs?
    By CaysE in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-12-2008, 07:16 PM
  3. WTB Rear B6 Estate Foglight Lens
    By djsky in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-04-2008, 07:35 PM
  4. 99 a4 foglight cover
    By tottie24 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-03-2008, 01:13 AM
  5. 1.8T Sport: Rear Foglight
    By A4Chris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-12-2007, 11:36 AM
