Thread: Re use of bolts.
  1. Re use of bolts.
    Jan 2008
    Was just about to put back the turbo and manifolds etc when I noticed in Elsawin you have to replace the bolts to the cat, heat shield to manifold and so on. Is this absolutely necessary to replace all these bolt?
    Thanks.
    audi a4 1.9tdi Avant PD engine. 2000
  2. Re: Re use of bolts.
    Mar 2016
    Minervois, France
    53 Post(s)
    Yes. If they are stretch bolts and were installed correctly they have been stretched to their elastic limit, so the installation instructions are no longer valid, and there is now no way of knowing how much torque they need.
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
  3. Re: Re use of bolts.
    Jan 2008
    OK, thanks, seems odd you need new ones on the manifold heat shield, cat to turbo I can understand.
  4. Re: Re use of bolts.
    Jan 2008
    Actually I made a mistake, it's not the bolts but the nuts that apparently need changing, does the same apply to them as well?
  5. Re: Re use of bolts.
    Mar 2016
    Minervois, France
    53 Post(s)
    No idea. Maybe because they corrode, or weaken due to the temperature. Perhaps someone here knows another reason.
    They should be cheap enough anyway. Personally I'd use standard off-the-shelf nuts.
  6. Re: Re use of bolts.
    May 2014
    Darlington
    78 Post(s)
    Yes, 100% change them, if you don't they will keep coming lose. The nut is pinched at the top so they kind of look oval when new, after many years and when removed that pinch is gone so the nuts will keep coming lose.
  7. Re: Re use of bolts.
    Jan 2008
    When I first did a search they were £8 plus per bolt that I was seeing, and if you need all the manifold bolts, manifold heat shield, and turbo bolts your talking 15 bolts and more.
    But once I knew they were M8 self tapping nuts I found them for a lot cheaper than that.
  8. Re: Re use of bolts.
    May 2014
    Darlington
    78 Post(s)
    They are about 65p each from Audi.
  1. Rear Pad Bolts
    By jonathanfenton in forum A7 - S7
    Last Post: 22-04-2019, 09:23 AM
  2. Question Bolts for brake caliper '7mm Hex bolts'
    By geoff eeles in forum Golf MK4 - 1999 - 2004
    Last Post: 01-08-2012, 07:59 PM
  3. akn big eng bolts
    By meganall in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-02-2012, 06:55 PM
  4. Bolts in rear pad set
    By mowjoe in forum Golf MK4 - 1999 - 2004
    Last Post: 04-04-2009, 09:19 PM
  5. Big End Bolts Again
    By marshp in forum Golf MK3 - 1993 - 1999
    Last Post: 17-08-2008, 08:59 PM
