Thread: P2002, p0544 error codes
Results 1 to 10 of 11
  1. P2002, p0544 error codes
    Mar 2018
    wales
    I've got a 2009 A3 TDI 2.0 170 cbbb engine.
    Everyday I scan the car and I get p2002 up and sometimes I'll get p2002 and p0544. Sometimes the glow plug light will also flash and sometimes the car will produce a lot of smoke. Most of the times it drives perfectly fine. Where do I start? Changing the EGT sensor under the turbo or changing the exhaust pressure sensor ? I've got VCDS but not sure what to actually check to narrow down the problem. Do I need to check the soot levels or do a force regen ?
    8194 - Particulate Trap Bank 1
    P2002 - 000 - Efficiency Below Threshold
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 11
    Reset counter: 255
    Mileage: 352996 km
    Time Indication: 0
    Date: 2019.04.15
    Time: 06:58:53
    Freeze Frame:
    RPM: 2001 /min
    Speed: 106.0 km/h
    Pressure: 3 mbar
    Hex Value: 0xFF01
    Temperature: 270.0°C
    (no units): 209.1
    Mileage: 300 km
    001348 - Sensor 1 for Exhaust Temp Bank 1 (G235)
    P0544 - 000 - Circuit Malfunction - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 11
    Reset counter: 255
    Mileage: 352996 km
    Time Indication: 0
    Date: 2019.04.15
  2. P2002, p0544 error codes
    Jun 2016
    Glasgow
    What’s the max dpf pressure during road test?
    Check with second person monitoring the laptop via measuring blocks.
  3. Re: P2002, p0544 error codes
    Mar 2018
    wales
    Sorry to be annoying how do I get that up ?
  4. P2002, p0544 error codes
    Jun 2016
    Glasgow
    In VCDS, in the area you can read and clear the faults you have an option to view “measuring blocks”, or, if available, “advanced measuring blocks”.
    *For measuring blocks: cycle through until you find the required data (someone else will know exact designation, but should be obvious).
    *For advanced measuring blocks: simply check the box of the data you want to stream.
  5. Re: P2002, p0544 error codes
    Mar 2018
    wales
    Checked some of the figures on adv mes and showed these
    Oil ash volume 0ml
    Carbon mass (spec) 23.7
    Carbon mass (act) 0
  6. Re: P2002, p0544 error codes
    Mar 2018
    wales
    Also shows driven distance since last regen 480km
    When I tick the boxes for
    Temp prior turbo shows 132oC
    Temp prior particulate filter Blank
    Temp after particulate filter Blank
    Should the sensors on the particulate filter be showing some temps ?
  7. Re: P2002, p0544 error codes
    Jun 2016
    Glasgow
    Need the max pressure value from road test.
  8. Re: P2002, p0544 error codes
    Mar 2018
    wales
    Took the car for a spin now and I put my foot down. Around 3500revs it hesitated then the power came back. Few seconds later the car started smoking a lot. Scanned it and came up with both codes again. Switched the car off and on again and its stopped smoking
  9. Re: P2002, p0544 error codes
    Mar 2018
    wales
    Checking adv mes now and is it
    Particulate filter pressure -5mbar
    Particulate filter offset 0mbar ?
  10. Re: P2002, p0544 error codes
    Jun 2016
    Glasgow
    If you got 5mbar as the max value on road test either you have a pipe blown off/split or the sensor is faulty.
    Inspect pipes to pressure sensor.
  1. Please Help Error code first one P2002
    By teddy2k5 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-06-2014, 12:12 PM
  2. Error codes help
    By magic123 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 10-09-2013, 09:15 AM
  3. 2 error codes
    By laur in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-06-2011, 10:54 PM
  4. does anyone know what these error codes mean
    By DAVYO in forum Touran - Sharan - Caravelle
    Last Post: 07-01-2010, 04:20 PM
  5. Error Codes HELP
    By csducks in forum VCDS - Help Requests
    Last Post: 08-05-2009, 11:40 PM
