Thread: Rear wiper motor washer leak
  1. Rear wiper motor washer leak
    Jul 2009
    uk
    Rear washer not been working for awhile.
    Took the rear wiper motor apart and found that the washer connection to the wiper spindle has been leaking into the gearbox.
    Any clues where I could get the plastic connection to the spindle that is fitted in the motor gearbox cover.
    Cleaned and re-greased till problem solved.
    thanks
    2010 A6 C6-Avant 2.7 TDi LeMans (FaceLift)
  2. Re: Rear wiper motor washer leak
    Mar 2011
    london
    you have to replace the whole motor common fault
    1 1 0
  3. Re: Rear wiper motor washer leak
    Jul 2009
    uk
    Thanks, I guessed that.
    Not doing that just yet all for a bit of plastic, will try and find an alternative fix.
  4. Re: Rear wiper motor washer leak
    Near Blackpool
    48 Post(s)
    Some have had success using a biro pen. Amazon strangely stock the Valeo motor which from memory was half the price of the TPS Audi stamped Valeo unit. Replaced mine twice now so cats had 3 in total. The amount of cars I see with a rear wiper stuck in a random position is embarrassing! Mk3 and 4 golf also had same issue but VW used to sell a repair kit for the mk3 variant motor but didn’t for the 4. They used to have a copper tube that was lubbed then snapped when it went dry.
  5. Re: Rear wiper motor washer leak
    May 2012
    Everywhere
    308 Post(s)
    Valeo are French junk , buy Bosch .
  6. Re: Rear wiper motor washer leak
    Jul 2009
    uk
    Thanks,
    But dont see how a biro pen would be of use, as the washer fluid goes up the center of the wiper spindle. Not as the VW or other models have the washer fluid tube fixed and turns inside the wiper spindle.
    The gearbox cover has square plastic connector, this fits over the end of the spindle when assembled. This is where the leak is between the spindle and connector.
    Seems daft having to pay £50 for a motor where the plastic bit would be £1.
  1. A3 56 Plate - Rear washer motor repair
    By LB94 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-03-2023, 01:41 AM
  2. Rear washer motor leaking
    By Redcar01 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-11-2015, 11:02 AM
  3. Rear Washer motor
    By 1st time buyer in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-04-2015, 05:53 PM
  4. A4 Avant - Rear Washer Bottle / Motor / Washer Pipe routing
    By mumutley in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-03-2013, 09:18 PM
  5. rear wiper washer leak causing bose amp problem on avant
    By alfie155 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-08-2011, 06:46 PM
